beginner for mini2440
vijay
Hi guys,
I am new to linux, can anyone help me to understand the drivers developed
for mini2440.
i went through the driver of led.
static int sbc2440_leds_ioctl(
struct inode *inode,
struct file *file,
unsigned int cmd,
unsigned long arg)
i am not able to understand why inode,file, cmd, arg is needed.
what is misc register.
how the led application program(.o) will run the led driver(.ko).
so please anybody can help?
Juergen Beisert
Userland apps open a device node and can send special commands via IOCTL to
the corresponding driver "behind" the device node.
Zhang Biao
There is a standard led framework in the newer linux kernel, which is
encouraged to use.
mohansai
for mini2440.
struct file *file,
unsigned int cmd,
unsigned long arg)
Juergen Beisert
Use a recent Linux kernel and you can control the LEDs via simple accesses
to "/sys/class/leds/...". For example read
www.pengutronix.de/oselas/bsp/pengutronix/download/OSELAS.BSP-Pengutronix-Mini24
40-Quickstart.pdf,
section 8.6 to get an idea how it works in recent kernels.
clarkli
<linux device driver> will answer all your questions.
Sushant
Read the LDD or Linux Kernel Development book
misc register is the register the your Driver in kernel space
