I'm trying to install a ANDROID 4.0.3 image in the ..\images\Android of the original CD but cant make it. I'm open a terminal window (RS232) and get the follow information: Superboot-210 Ver: 1.16(20130204) CPU: S5PV210 1GHz RAM: 512MB NAND: 1GB(SLC) ID:ECD35195 Touch Device: 1-wire LCD Type: S70(Auto) Installing OS 'ANDROID' Installing bootloader... file: /images/Superboot210.bin: 528 KB(540672 Byte) Installing bootloader succeed Installing kernel... file: /images/Android/zImage: 4 MB(4620276 Byte) Installing kernel succeed Installing yaffs2-image... Installing yaffs2-image failed In the line "Installing yaffs2-image failed" the instalation fail!... can anyone help me?
Installing yaffs2-image faiIed...
You need probably need to recreate the image file but formatted for SLC nand rather than MLC nand. I can't remember the exact procedure but you can use the rootfs tarball that is in the android folder, as root unpack it to a temp folder somewhere, then use one of the mktools binaries to create an slc image (hint, the binary you want is probably the one without MLC in the name and you will need to run it on 32bit linux). FYI, unless there's a specific reason to use the original, you should really look at the latest android 4.0.3, it's been updated with the x86 ethernet patch (a patch that originated on x86 version of android that gives full support to ethernet from within the android framework) + a couple of other things.
