Hi, I am doing a project using the MINI2440 friendly ARM.I made an application to send some data through the serial port UART0 of the board.It sends the data perfectly to a computer's hyperterminal but when i connect a zigbee in between the MINI2440 and computer nothing is received.what may be the problem? baudrate = 9600 8N1 configuration is being used.
problem when interfacing zigbee with MINI2440
What do you mean "connect a zigbee in between the mini2440 and computer"? How are you making your connection?
