All the instructionals for installing android on the Mini2440 use a file called 'android-kernel-20090825.tar.gz'. I believe it used to be in the download section here but I don't see a link for it anymore. Does anyone know where this file can be located? Or perhaps how to re-create it?
Android Kernel for Mini2440?
Hi M Jones the link for download is here: Kernel: http://www.mediafire.com/?xo882so6n8b2ssw Fs: http://www.mediafire.com/?x2im2b81f8yld2x For more information: http://theroomtech.blogspot.com/
Hi, Does anyone know of a good link describing the file setup required for running android from an sd card? Currently setting up a card using 3 partitions: 1: Linux swap 2: ext2 3: ext3 I currently have uImage on partition 2 and android file system on partition 3. I'm having trouble finding info on exactly what needs to be in each partition, so if you happen to know or know of a good link, it would be very helpful. Thanks. Mark P.S. I did get android up and running without the SD card, but seems to be running out of memory when attempting to install anything else, so I'm just trying to get some more space.
for the SD card, I think it has to contain : - uImage, MLO (x-loader), u-boot.img, uEnv.txt (u-boot cmds) on FAT partition - Android FS on ext4 partition ( chmod 775 on that ) I used this config for booting from SDcard using Texas Instrment Dev Board.
