are three days I'm trying to flash the kernel image with superboot but no result. I used superboot as documentation, created "images" directory in the FAT partition and copied the right files. I set the switch to sdBoot and powered the board but no message appears in the serial monitor and the display is white, no alarm buzzer or LED indications. What is the problem? Someone was able to write the kernel in a tiny210v2?
impossible to write the kernel with tiny210v2
Hi Marco, Did you fund a solution for this problem? I am also stuck in this point. I would appreciate any help here.
