Hi! I need help with my QTopia Design, I installed everything ok, but I can't run the Designer correctly, its appear 95% transparent, I cant use, just can see " file " " help " in toolbar, but when I use ALT+TAB its show me a preview, and there I can see the Designer Tool, working perfectly, but when I go there, Its not, please, I have Ubunto 12.10, I downloaded Compiz and Unmarked all Visual Effects, but nothig happened :/ Thanks guys!
Problems QTopia 2.2.0 - Designer Tool is transparent!
Hi, i want to compile a qt file in mini2440(P35). i made qt executable file according to arm version. after that when am trying to start that application it is giving the following error [root@FriendlyARM /bin]# start /bin/Qt: line 1: syntax error: word unexpected (expecting ")") [root@FriendlyARM /bin]# how to solve this error am not getting where the error is exactly whether in the qt file or in arm board(process).... Thanks in advance.
First I would make certain you are starting the program correctly ... I think it is suppose to be: start -qws Then search for : word unexpected (expecting ")") on this site then Google for <mini2440vietnam> and read through his Qt tutorials.
