Hi there, I connected to wifi module succesfully and access google OK. But i dont know i can't ping to my laptop which connect to Wifi module, too. Please help me. Best regards
mini2440 cannot ping to other IP address
Well, on your mini2440 type in ifconfig on the command line and note the IP address (192.168.1.230?) Then on your laptop type in ifconfig (Linux) or ipconfig (Windows) and see what its IP address is. On the mini2440 type in ping address_of_your_laptop I imagine you can access the WWW from your laptop.
Were you able to ping across your wired interface (eth0) BEFORE you got your WiFi working? If so, can you still ping across your wired interface?
Can you ping 8.8.8.8 ? Is Busybox ping compiled into the kernel? I had to use inetutils version of ping, as the Busybox version either didn't work or didn't have a feature I needed. Thought I had better check my resolv.conf (note the spelling) and I don't have 8.8.8.8 in there (anymore) however I have the addresses of my local name servers, ie 192.168.1.1 and 192.168.2.1
You had better describe your whole setup there: ifconfig of the mini2440? ifconfig of the Linux host or ipconfig of a Windows host? IP address of any routers (ADSL or wirless)and your port forwarding rules on the router? For example: - mini2440 connected to a switching hub - PC connected to the switching hub - switching hub connected to ?? And then which unit (mini2440/PC) can ping what.
