I am new to Linux and S3C6410. Referring the manual i tried to cross
compile for 6410. But the manual tells just to extract the cross compiler
folder. The commands as follows
cd /witech
mkdir /usr/local/arm
tar xjvf cross-4.2.2-eabi.tar.bz2 -C /usr/local/arm
Only the above command is enough?
I also tried to install bootloader with following codes in manual:
tar xzf u-boot-1.1.6-2636.tgz
cd u-boot1.1.6
make smdk6410_config
make
But i get the error as arm-linux-gcc not found.I also install arm-linux-gcc
with this command :
sudo apt-get install gcc-arm-linux-gnueabi
Kindly guide me with step by step procedure to install cross-compiler and
boot-loader
I also attached the manual for S3C6410
Thanks & Regards
Pradeep
S3C6410
Check out this tutorial http://code.google.com/p/mini6410-debian/wiki/Tutorial#7._Compiling_the_... - see step 7 for a cros-compiler, and copy n paste instructions on how to use it.
