Hi there, I'm wrriting an application in Qt on mini2440 but when i take project to mini2440, my buttons is very small. Please tell me size of LCD mini2440 which i can drag to fit with my LCD x35. And a question anymore :D What is Boa browser on mini2440? i only see Konqueror Browser :D My LCD is x35, so can i build kernel with which LCD ? Thanks in advance. Best regards, Quynh
size of LCD mini2440 in QT
There are environment variables that you can set to control size of the image on the target and I thought you could also do that in your Qt application. Try: printenv and you might see something like: QWS_DISPLAY=LinuxFb:nographics ........ :mmWidth=120:mmHeight=160 then there are variables you can set to different values, for example setenv QWS_DISPLAY=LinuxFb:nographics ........ :mmWidth=240:mmHeight=320 then saveenv Try that and see what happens. Or better still find out how to set these sizes in your Qt application. Boa is a web server not browser > My LCD is x35, so can i build kernel with which LCD ? I think there are several different screens that you can compile for with FriendlyArm or Pengutronix code sources. If you try to use a mainline kernel source ... then good luck!
thanks davef, you're kindly :D i have set size of widget 320x240 and it fit to my lcd. Best regards.
