Hi all, I am trying to understand the code below does jumping to an interrupt handler: - Upon receiving an IRQ interrupt, it jumps to the exception vector table of IRQ (0x0000.0018) -From that table, it jumps to the below sub routine: IsrIRQ sub sp,sp,#4 ;reserved for PC stmfd sp!,{r8-r9} ldr r9,=INTOFFSET ldr r9,[r9] ldr r8,=HandleEINT0 add r8,r8,r9,lsl #2 ldr r8,[r8] str r8,[sp,#8] ldmfd sp!,{r8-r9,pc} I uses S3C2440. INTOFFSET is a register whose value indicates which interrupt has been active, HandleEINT0 is the start address of interrupt handler table located in DRAM - I see that it calculates the address of the corresponding ISR for the interrupt and stores to R8 But I do not see where it jumps to that ISR to serve the interrupt!!!!! (I see it just push to the stack) Do I miss something? Is the code correct (It is from a reference project)? Thanks, Huy
