Curious to know if anyone out there is using a 3.x series kernel with the Mini6410? I have tried 3.2.43, 3.4.40, and 3.8.7, applying the patches supplied by Pengutronix, as part of a from source build, and I keep having the kernel hang up when trying to mount the root fs. If I reset the board a couple of times, it does eventually start, but I keep seeing a running "Too large timeout requested for CMD25" error coming from the mmc driver. Found out that this is a known issue - it is resolved by sending the message to debug, rather than displaying (er, wtf kind of fix is this?) - and applying the "fix" makes the messages go away (duh), but the system still doesn't seem to be running right. I also have no working display on the touchscreen; only console access right now is serial. I saw on the Pengutronix site that there is a known issue with using SDHC cards (I am using a class 10, 8GB SDHC). The "fix" for this is "don't use them". (again, and no offense to Juergen, but this is a "fix"?) I don't think the issue is with the SDHC cards - it has something to do with the kernel, because when I load the 2.6.38 kernel, the card comes up, so I am assuming that there is a setting/parameter somewhere in the kernel code that changed from the 2.6 series to the 3.x series and is causing this odd behavior. If I can manage to find it, I'll post how to make it work. Long and short of it, the only kernel I have been able to boot without any errors and with decent performance is the 2.6.38 provided by FriendlyARM. Is it impossible to use any other kernel? Is there a set of known good patches that can be applied to a stock kernel.org kernel that will work with the Mini6410 and provide support for audio, touchscreen, GPIO, etc? My goal is to be able to work with a generic setup, as much as is reasonably possible, rather than be tied to FA support, which seems to be focused on the Tiny/Mini210 presently. Any help/suggestions would be greatly appreciated.
Using 3.x series kernel with Mini6410
Quick update ... was able to boot 3.8.7 with the 8GB SDHC card, no reset required. Apparently, adding "rootdelay=8" to my kernel boot args was all it needed to give the board a chance to recognize the card and boot properly. So that solves that part of the dilemma. Still no display on the touchscreen, so I guess that'll be the next thing to look at ... Still hoping that someone out there has a success story to share (hints, gotchas, etc) using the 3.x series kernel.
@Juergen Thanks, will try that. I also noticed that trying to compile on the system is horrendously slow ... I compiled the "less" utility - took almost as much time as it did to compile gcc on my development machine. There is something definitely off with the mmc/sdhci support in the 3.x series. Same board, same SD card, 2.6 kernel and the same compilation was almost as fast as on my development machine. I expect some slow-down, but not to the point that I am seeing. It's a shame because the system itself feels relatively smooth ... until you have to do I/O to the SD card.
Welcome in the world of updates. If you feel you found a regression you should send your observation to LKML to get it fixed. But first you should try with 3.9rc. Maybe it is already fixed.
Still seeing slow compile time, but that may just be the limit of the board at this point ... I did notice that SPI support was not turned on in the kernel, so I enabled that. Major performance boost for the SD card. Going through the kernel configuration now to see what else was not enabled but was enabled by FA in their 2.6 config.
A major performance boost for the SD card when you enable SPI????? The S3C6410 SoC has dedicated hardware for SD cards and to drive an SPI bus. They should not depend on each other. Except there is a bug in the software... (clock routing for example). But this would be another regression.
Yes, I thought that odd as well, but it was a discrepancy between the configuration I have in the 2.6 kernel build and that I had in the 3.8 kernel build.
