New gcc for cross compile
elmo23x
Hi all,
FriendlyARM is not releasing any new gcc compiler for the last years! So I
decided to create my own, based on gcc 4.7 and 4.8, that you can download
from here:
http://tuxamito.com/wiki/index.php/Cross-compile_toolchains
These generate code optimized for the s3c6410 cpu (core arm1176jzf-s, which
is the same as in the RaspberryPI).
If you have any comments, just write them here. I hope they are useful!
elmo23x
I forgot to say that if you try to compile the supplied kernel (latest I
know is 2.6.38) it will not boot with this version unless you apply the
patch described here:
http://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/commit/?i...
Newer kernels (from 3.2) will not have this issue.
