Hello! Maybe my question can be strange, and it is, but I have a problem, a lot problems... I won a mini2440 that have a Linux running, but I don't know what is exactly, derbian or fedora or ubuntu, (I'm sure that it's not andriod)... It's a big problem? I have other problem, I found some tutorials, but I don't know what step I'm in... Because the Linux is running, but, what tool can I use to creat apps, to build and run on my friendlyarm mini 2440, I read that i need QTopia, so I thinking, if I have linux running, it's just download QTopia, creat a program, and export to Mini 2440? Thanks! Sorry my bad english, and my low knowedge about 2440mini ps: I'm a C programmer, and have experience with Arduino, that's it! Thankss!!
How to start with mini2440 that someone already started ?
Do you get to a flashing cursor prompt on the screen? Then "uname -r" Or, with the proper RS232 cable plugged into the 9 pin connector and your PC and running minicom or hyperterminal at 115200boud and 8N1 what do you see as it boots up?
Sorry, I don't know if I undertood you, but when a turn on the 2440mini he starts an OS, notmal, maybe fedora... I never saw this " flashing cursor prompt " and i didn't plugged any cable, just for energy... Maybe is better I reset the mini2440 and start again? Thanks davef!!
Do you see anything on the screen? The usual way to figure out what is happening during the boot process is to run a terminal program on a host computer and connect it to the target. For the mini2440 I use a RS232 to USB converter. One end plugged into the DB9 connector on the mini2440 and the other end to a another computer (remote terminal). You will not get very far with "starting again" if you can not do what I just described.
Devef, I think, if I understood him right, that the device is booting into Linux and everything is fine. He is just afraid that the previous owner might have done some alterations with the kernel and wants to "reset" the system by installing everything new if necessary. Is there a way to check if the kernel/system os is still unaltered? Berthold
I would expect that he would at least see a login prompt and a flashing cursor. To see how the kernel is configured search for zcat /proc/config.gz .config on Google. There is a specific box to tick in kernel config to enable this feature. So, if there is no /proc/config.gz file maybe you are out of luck. Then use Meld to look for differences between that and whatever else you want to use as the "beginning" kernel configuration (.config).
zcat /proc/config.gz .config Maybe,is not appropriate! try zcat /proc/config.gz > /home/my_kernel_config.txt
Thanks davef and Berthold! Berthold, exactly! My problem is: what I need to do to check if everything is right, and what I need to install to start to programming my apps, I just know that some OS is running. davef, I never saw this prompt(at least, I never tryed to enter), but I see the cursor, the browser, a lot of icons, I don't know if it's what you are asking Thanks guys!
Find an icon that looks like a terminal and start entering commmands or browse around your filesystem. Qtopia 2.2 was the window manager for the standard factory install. People have put Windows CE on these units. Did you have to do a screen calibration? There is a lot of useful documentation here: http://www.friendlyarm.net/dl.php?file=mini2440_manual.pdf
Hello davef! I turned on my mini2440, and stated to check about my mini to tell to you, so I have more details now, and some new. 1- The screen calibration is ok, the last owner did it perfectly! I can use the keyboard on screen without problems! 2- I used the a command on terminal " uname -a " that show what OS is running, and the answer is: " Linux FriendlyARM 2.6.32.2-FriendlyARM. 3- I saw here an app called Start Qt.4.6.3, and I thought it`s a IDE, or some place to write my codes, but its strange, have some examples... It probably isn't a QTopia... 4- I know my OS, and the screen calibration is okay, what's my next step? install IDE? how I do? Thanks!!
1. Good 2. Most likely the standard factory install 3. There is a later version of Qt, it looks like 4.6.3 that came bundled with the later versions of the mini2440. It is a window manager not an IDE. 3. For this machine all code is cross-compiled on a host, usually running Linux then downloaded to run on the target. 4. I don't think you will be able to run any sort of IDE on the target. What were you thinking of using? Next step? What do you want to do or learn?
Thanks davef! I want to make a code that turn on and off LED's, I know programming C, but I don't know where I can make the desing(what IDE I use) and how I compile my codes, or how I run the code in my 2440mini. In short, what I want to do and learn is what IDE I have to donwload, and how I compile and run it. Thanks davef!
Google this file: InstallingtheARMGCCCompilerandCompilingProgramsfortheMicro2440.pdf There is an LED example on the factory DVD. I would also suggest: http://www.friendlyarm.net/forum/topic/5123 and just control an LED from user space. The only code I have "written" was the above tutorial. I write all my code on ATMEL AVR chips and control them from the mini2440 via USB.
