You can use PVBROWSER with mini2440. A free and fully open source Qt SCADA. More information at pvbrowser.org. A quick and great tool for domotics and industrial automation. Download client (binary) and server libraries al xvedra.blogspot.com.es for mini2440.
Free Qt SCADA for mini2440
http://xvedra.blogspot.co.nz/ Looks interesting. Dave
Which version of GCC did you use to cross-compile this? I don't seem to be allowed to download the source to compile with my toolchain. As found at the beginning of Chapter 2 in the manual.
First question still relevant. Downloaded the source OK from the web site. Links in the manual are broken.
Hi davef, I do not remember if I have used ARM-Linux GCC 4.4.3 or 4.3.2, I think both are valid. I have compiled it with Qt Creator like IDE. Which manual exactly is broken?
Manual: pv.en.pdf I wanted to compile the source using the Pengutronix BSP but there is a problem with getting Qt Creator to find the library paths. I have everything I need from your side, to try working through some of your examples. Even with Babelfish I couldn't work out how to post a comment on your blog! Thanks for replying here. Dave
