Install Ubuntu on Tiny210
Amir.s
Hi you all
I'm trying to install ubuntu on tiny210 and i have some question;)
1.how i can make ubuntu image?
2.I flowing step by step this tutorial but not work
http://armworks.cc/index.php?title=Mini210S_ubuntu_sd
when i turn on Tiny210 the screen(H43) always is white and repeatedly beep
3.can i change file system from ext4 to ext3?
Reggie
Connect to the serial console then you can see what's wrong.
1. Search this forum for ubuntu, I posted a method on how to make an ubuntu
2. That tutorial is for running from SD, white screen and repeatedly beep
isn't enough information
3. Yes, you can on the SD card but you'll need to edit the commandline in
friendlyarm.ini (rootfstype)
you can make an ubuntu image fairly easily but if you're burning to nand it
won't help, the resulting image file is too big, its 2.1GB and even if you
do have a mini210S with 4GB of nand, it still won't work because superboot
is not capable of burning files bigger than 2GB
Amir.s
Tnx for reply.
i have fundamental question
Can i install ubuntu on Tiny210???
i solve my problem with SD and my Tiny210 boot successfully,
my ext4 partition get address /dev/mmcblk0p5 in my PC instead of
/dev/mmcblk0p2
i change /dev/mmcblk0p2 in FriendlyARM.ini to /dev/mmcblk0p5.
when i select Linux from boot list all process done so fast and when i
switch S2 to NAND and turn on again :(
NOTHING
--------------------------This is my
FriendlyARM.ini------------------------
#This line cannot be removed. by FriendlyARM(www.arm9.net)
CheckOneButton=No
Action = Run
OS = Linux
LCD-Mode = Yes
LCD-Type = H43
LowFormat = No
VerifyNandWrite = No
CheckCRC32=No
StatusType = LED
################### Linux ####################
Linux-BootLoader = Superboot210.bin
Linux-Kernel = Linux/zImage
Linux-CommandLine = root=/dev/mmcblk0p5 rootfstype=ext4
console=ttySAC0,115200 init=/sbin/init
Amir.s
i try both "Action = Run" and "Action = Install"
Reggie
All you should need to do is use the 'install' option, the kernel runs from
nand, so you can try any superboot.bin that you know works on nand, once
it's burnt, turn the switch to nand and power cycle the board.
If there is anything else wrong, I can't tell you what it is.  I don't have
a tiny210, I only tested the ubuntu SD on a mini210S.
