how to get 1024 X 768 resolution output on tiny210?
satish
Using Tiny210v2 how to get 1024x768 or higher resolution in HDMI monitor.
I changed Friendlyarm.ini file as below but no use..
"LCD-Type = HDMI720P60"
kuhdav
If you want to see the video out on HDMI monitor you should set the right
"#define" in file option.h and rebuild the BSP.
Are you sure that this resolution is supported? I remember 1920x1080 or
1280x720 etc but not 1024x768.
good luck
satish
Thanks for your reply Kudav.
