powertop mini2440
Trying to run powertop.
CONFIG_DEBUG_KERNEL is enabled but I don't get any stats.
< Detailed C-state information is not available.>
Is there something else I need to enable in the kernel?
Thanks,
Dave
Juergen Beisert
I didn't use this tool yet on ARM, but maybe this text from the archive's
README will help you:
Kernel Parameters:
PowerTOP needs some kernel config options enabled in order function
properly.
As of linux-3.3.0 these are (list probably incomplete):
CONFIG_NO_HZ
CONFIG_HIGH_RES_TIMERS
CONFIG_HPET_TIMER
CONFIG_CPU_FREQ_GOV_ONDEMAND
CONFIG_USB_SUSPEND
CONFIG_SND_AC97_POWER_SAVE
CONFIG_TIMER_STATS
CONFIG_PERF_EVENTS
CONFIG_PERF_COUNTERS
CONFIG_TRACEPOINTS
CONFIG_TRACING
CONFIG_EVENT_POWER_TRACING_DEPRECATED
ACPI_PROCFS_POWER
At least the "ACPI"-keyword in the list suggests x86 architecture. Also the
"C-state" error message you face makes me feel it will work on x86 only.
But I'm not sure.
Thanks.
I read some comments about it may not work on ARM platforms.  3 or 4
suggestions are given at random every 5 seconds, one of them suggesting to
enable CONFIG_NO_HZ
Spent quite a bit of time reading about tickless kernels becoming the norm
back in 2.6.? then noticed the default on 3.7.1-ptx-2012.12.0 was
CONFIG_NO_HZ disabled.
Which README are you reading?  The one in the powertop-1.11 folder says
nothing about kernel options.
Dave
Juergen Beisert
The README in this archive:
https://01.org/powertop/sites/default/files/downloads/powertop-2.3.tar.gz
