Deployed Dotnet file not working after restart in mini6410,
anbu
Sub:Deployed Dotnet file not working after restart in mini6410,
Help req.
Step By Step process done. Such as follows,
1. I have installed the winCE6.0 OS
2. Already I have created one compact Vb.net2008 application software, I
have deployed in mini 6410 through the usb.
3. Now Working this appllication.(In this application,I have used some
serial ports to communicate with the printer,Weight balance, to on relay (3
ports).This application software used the database as compact
sqlserver2008, to store and retrieve the data.)
4. If I restarts the device, Deployed same program not there in program
files(device).
5. Again i deployed newly,working same software.
6. But before restart, I am copying deployed file into mem.card or nand
flash, and then i restarted. File is there in either mem.card or nand
flash. but not working the software.
Problem is:
7. While deploying vb.net software through the PC, PC is installing some
support files in windows folder(in mini6410) and in deploying location(in
mini6410). after restarts all those files are deleting.
if we copy those deployed folder to mem.card or nandflash, those files will
not delete.but support files are deleted in windows.
8. But i have tried another one, i have changed the properties as read only
of that support files in windows folder.that is also not working, all
support files are deleted after restart.
Solution need:
1. how do i deploy all support files, main deploying files in nand flash or
in mem.card.
2. If you are having some other solution that is also need.
Note.
 I have tried same this application in Mini2440 working well, but i am
having memory low issue we need extra memory, and some serial port is not
working properly. so that i have tried mini6410.
Thanks & welcome by
B.S.Anbalagan
Dezso
Your os build is non persistent file system.
The .net component what was installed and registered during deploy its
simple disappear after reboot and that is why even the file from SD card
won't run.
Build new os, select rom only fs and try again.
Anbu
Thanks for your reply Mr.Dezso,
But I do not know to build OS with rom only fs. Just i loaded OS directly
from the sd card and selected the wince os. thats all.
Can you explain please..
Thanks & welcome by
B.S.Anbalagan
Dezso
Install vs2008
Install wince6
Install wince6r2
Install wince6r3
Install 2hr worth of updates.
Download and install BSP
Change file system to rom only.
Upload new image.
