Hi, I have a problem running Ubuntu from a SD card. During the boot process I got the following message: ------------------------------- /init: line 103: can't open /r/dev/console: no such file Kernel panic - not syncing: Attempted to kill init! ------------------------------- and the board stopped loading Ubuntu. The last few lines of messages at Hyper terminal are: ------------------------------- Freeing init memory: 1412K FAT: utf8 is not a recommended IO charset for FAT filesystems, filesystem will b e case sensitive! losetup: /dev/loop0: No such file or directory bio too big device loop0 (2 > 0) EXT3-fs (loop0): error: unable to read superblock mount: mounting /dev/loop0 on /r failed: Invalid argument mount: mounting /sdcard on /r/sdcard failed: No such file or directory 1Wire touchscreen OK /init: line 103: can't open /r/dev/console: no such file Kernel panic - not syncing: Attempted to kill init! [<c0178c44>] (unwind_backtrace+0x0/0xe4) from [<c05159c8>] (panic+0x58/0x174) [<c05159c8>] (panic+0x58/0x174) from [<c018aeb0>] (do_exit+0x68/0x5e4) [<c018aeb0>] (do_exit+0x68/0x5e4) from [<c018b6f0>] (do_group_exit+0x90/0xc4) [<c018b6f0>] (do_group_exit+0x90/0xc4) from [<c018b734>] (sys_exit_group+0x10/0x 18) [<c018b734>] (sys_exit_group+0x10/0x18) from [<c01735e0>] (ret_fast_syscall+0x0/ 0x30) one_wire_status: 2 ------------------------------- I would appreciate any help! Thanks!
