Anyone know how to install libudev so that I can cross compile? My source compiles and runs OK on my x86 linux, but cannot get it to compile for my Tiny210 using the arm cross compiler. Thanks Phil
installing libudev
I have installed libudev-dev from debian (armel version) using xapt and installed the libudev.h, libudev.a, libudev.so.0 and libudev.so.0.13.0 arm-none-linux-gnueabi-g++ -o test -g Main.o ../../../lib/linux/libphil.a -pthread -ludev /opt/FriendlyARM/toolschain/4.5.1/lib/gcc/arm-none-linux-gnueabi/4.5.1/../../../ ../arm-none-linux-gnueabi/bin/ld: error: /opt/FriendlyARM/toolschain/4.5.1/lib/gcc/arm-none-linux-gnueabi/4.5.1/../../../ ../arm-none-linux-gnueabi/lib/libudev.a(libudev.o) uses VFP register arguments, test does not /opt/FriendlyARM/toolschain/4.5.1/lib/gcc/arm-none-linux-gnueabi/4.5.1/../../../ ../arm-none-linux-gnueabi/bin/ld: /opt/FriendlyARM/toolschain/4.5.1/lib/gcc/arm-none-linux-gnueabi/4.5.1/../../../ ../arm-none-linux-gnueabi/lib/libudev.a(libudev.o): Unknown mandatory EABI object attribute 44 The "error: /opt/FriendlyARM/toolschain/4.5.1/lib/gcc/arm-none-linux-gnueabi/4.5.1/../../../ ../arm-none-linux-gnueabi/lib/libudev.a(libudev.o) uses VFP register arguments, test does not" I use: make CROSS_COMPILE=arm-none-linux-gnueabi- How can I change this to remove the VFP register aguments? The "Unknown manatory EABI object attribute 44" seems to be connection with the DIV instruction ???? Anyway googled and read endless pages, tried many ways to fix this so far without success. Any help or pointers are welcomed !!!
Solved.... I was using the latest libudev 175-7-1 Wheezy version when using the squeeze version 164-3 it compiled ok.
Could you please tell me how to install .deb on FriendlyARM board? I want to use libudev on the board, but failed. Thank you very much.
