Greetings. I am trying to compile a connection test with PostgreSQl 8.4 in Emdebian on a Mini2440. <code> #include <libpq-fe.h> </code> This command works: g++ -I/usr/include/postgresql/ -L/usr/lib/postgresql/8.4/lib/ -lpq -o PSQLTest PSQLTest2.cpp But this commando does not works: arm-linux-gnueabi-g++ -I/usr/include/postgresql/ -L/usr/lib/postgresql/8.4/lib/ -lpq -o PSQLTestEmdebian PSQLTest2.cpp <code> /usr/lib/gcc/arm-linux-gnueabi/4.3.5/../../../../arm-linux-gnueabi/bin/ld: cannot find -lpq collect2: ld returned 1 exit status </code> Someone has a tip? Regards. Fernando Vilmar Palha
Cross compile PostgreSQL client app
File you are looking for should be in directory /usr/arm-linux-gnueabi/lib. You can download http://packages.debian.org/libpq-dev for arm/armel architecture and install on your x86 development machine using dpkg-cross.
Greetings. Thank you Tomasz. The directory /usr/arm-linux-gnueabi/lib exists, but the libpq does not exists. I downloaded the file "libpq-dev_8.4.16-0squeeze1_armel.deb" from http://packages.debian.org/libpq-dev and I ran the command: dpkg-cross -a armel -i libpq-dev_8.4.16-0squeeze1_armel.deb But has many dependences. How I can install the library? I need download all dependences? Regards.
Hi. I followed the forum "http://web.archiveorange.com/archive/v/bWlyQyWPZWxX0fT5lt9L". I added the line in "/etc/apt/sources.list": deb http://security.debian.org/debian-security squeeze/updates main deb http://backports.debian.org/debian-backports squeeze-backports main I ran the commands: root@VM-Debian:/home/fvpalha# apt-cache search xapt xapt - retrieve, build and install libraries for cross-compiling root@VM-Debian:/home/fvpalha# apt-get install xapt root@VM-Debian:/home/fvpalha# xapt -a armel libpq-dev root@VM-Debian:/home/fvpalha/Downloads# ls /usr/arm-linux-gnueabi/lib/libpq* /usr/arm-linux-gnueabi/lib/libpq.a /usr/arm-linux-gnueabi/lib/libpq.so.5 /usr/arm-linux-gnueabi/lib/libpq.so /usr/arm-linux-gnueabi/lib/libpq.so.5.2 Now the command works: arm-linux-gnueabi-g++ -I/usr/include/postgresql/ -L/usr/arm-linux-gnueabi/lib/ -lpq -o PSQLTestEmdebian PSQLTest2.cpp Thank you.
