I'm using the 2.6.38 kernel source and 4.5.1 toolchain provided by FriendlyARM to build a kernel for the mini6410. The kernel will work 1 out of every 5 boots, the errors generated when it fails are: Freeing init memory: 1376K mmc0: new SD card at address e624 mmcblk0: mmc0:e624 SU02G 1.84 GiB mmcblk0: p1 mount: mounting /dev/mmcblk0p1 on /r failed: No such device or address 1Wire touchscreen OK /init: line 103: can't open /r/dev/console: no such file Kernel panic - not syncing: Attempted to kill init! [<c016fde8>] (unwind_backtrace+0x0/0xe4) from [<c033e200>] (panic+0x68/0x184) [<c033e200>] (panic+0x68/0x184) from [<c0180aac>] (do_exit+0x68/0x668) [<c0180aac>] (do_exit+0x68/0x668) from [<c01813d8>] (do_group_exit+0xb0/0xe4) [<c01813d8>] (do_group_exit+0xb0/0xe4) from [<c018141c>] (sys_exit_group+0x10/0x18) [<c018141c>] (sys_exit_group+0x10/0x18) from [<c016a640>] (ret_fast_syscall+0x0/0x30) one_wire_status: 2 Thanks, - David
Mini6410 - can't open /r/dev/console: no such file
After a bit of digging, I found the file FriendlyARM.cpio in the scripts directory. It appears this file is an initramfs image and has the script that is generating the error.
Turns out the problem can be solved by just disabling the initramfs image in the kernel config. Hope this helps someone else.
Hi David, that's one solution but it depends whether there is anything in the CPIO that could break things if it's missing, usually, all of the touchscreen setup is done in there, disabling the initramfs can cause the ts to not work especially if it uses ts_lib. However, if it's all working for you, more power to ya :-)
What is /r/dev/console? I only know /dev/console. Is this mini6410 specific? From mini2440 i never heard of that...
/r/ is the root device where the initramfs builds the root filesystem ready for handover to the switchroot function.
