Hello all, Im having some issues regarding the usb-rs232 converter (there are some speed incompatibilities because Im giving weird symbols) so I can not get into my mini2440, not even the console. Thats's why I wonder if I can get to ir through ethernet connection, is that possible? how can I achieve that? Thanks!
Is it possible to connect to mini2440 through ethernet?
How are you trying "to get into your mini2440". Via, minicom? Have you set the correct baudrate etc? telnet is a method of talking to your mini2440 via ethernet
Thanks for your reply davef ! The baudrate Im using is the 115200... but it's not working either. I bought my mini2440 since some months ago and I couldn't even test some program coz I can't communicate with it. telnet?? But is the telnet server on from the setup? H ow can I do that??
> But is the telnet server on from the setup? Good question, I don't know. Let's try to get the normal RS232 comms going. Haven't ever done this myself but I think if you connect the RXD and TXD pins together on the RS232 side of your adapter you can perform a "loopback test". I assume you haven't got access to a PC with a RS232 output running either Linux or Windows. (You can try Hyperterm to see if you can talk to the mini2440). Have you got any other USB to RS232 adapters? I know people have had issues with some models of adapters. A search here might turn them up for you. Can you test the adapter on another PC? Good luck!
I had the above shown problems with all PL2303 based adapters i used. This problem persists on any computer i used. After using adapters with the FTDI / FT232RL chipset i got no more noise or garbage when connecting over the serial port. Currently i am using the the Digitus DA-70156 adapter.
Hi Davef, Ive tested it with another cable but the same happened... I bought today a BAFI rs232 USB adapter on the internet so I will need to wait for it. Anyway, the converter that I firstly used is the one which came with the kit, should have worked anyway... Its not a problem on my computer, I know that. I bought it on Industrial ARMWorks, Im a kind of mad at them because of the bad converter they gave to me. Thanks for your reply!
Sean_h, could you please tell me how?? I connected an ethernet cable but there was no light nesr the port, so I guess the ethernet driver is not on yet. How can I achieve that? Thanks
Hi Javier - during the boot process you would see messages relating to the ethernet port. - watch out for a direct connection between PC and Minixxx and crossover cables. Use an ethernet switch (hub) it resolves this problem - ssh x.x.x.x ( from host where x.x.x.x is ip address of target ) - use ifconfig, netstat and nmap for resolving network issues - check your host firewall for opening appropriate port rgds
Hi Javier Yes, you require the root password for the mini2440. On mini2440: ifconfig eth0 If no IP address present: ifconfig eth0 10.0.0.20 (for example) From computer on network: ssh 10.0.0.20 ( and you will get something as follows ) The authenticity of host '10.0.0.20 (10.0.0.20)' can't be established. RSA key fingerprint is 80:c3:f0:48:dd:32:96:0b:84:7b:7a:09:e4:b8:08:e1. Are you sure you want to continue connecting (yes/no)? yes Warning: Permanently added '10.0.0.20' (RSA) to the list of known hosts. root@10.0.0.20's password: Enter the min2440 root password.
