Hi friends, I know insmod is used to install a module. But what if we want to replace the module. Can anyone tell me the command to do that? rmmod is used to remove the module, but if you say the command for replacing a module, it would be helpful.
how to edit a module installed
'insmod' is a command to insert a module from your file system into the running kernel. "rmmod" removes this loaded module from your running kernel. What do you mean with "replace the module"? On your file system?
