raza@raza-Inspiron-1564:/mnt/uc/sources/uClinux-dist$ make make -C tools/ucfront make[1]: Entering directory `/mnt/uc/sources/uClinux-dist/tools/ucfront' make[1]: Nothing to be done for `all'. make[1]: Leaving directory `/mnt/uc/sources/uClinux-dist/tools/ucfront' ln -sf /mnt/uc/sources/uClinux-dist/tools/ucfront/ucfront tools/ucfront-gcc ln -sf /mnt/uc/sources/uClinux-dist/tools/ucfront/ucfront tools/ucfront-g++ ln -sf /mnt/uc/sources/uClinux-dist/tools/ucfront/ucfront-ld tools/ucfront-ld ln -sf /mnt/uc/sources/uClinux-dist/tools/ucfront/jlibtool tools/jlibtool chmod +x tools/romfs-inst.sh tools/modules-alias.sh tools/build-udev-perms.sh make -C config automake make[1]: Entering directory `/mnt/uc/sources/uClinux-dist/config' make[1]: Nothing to be done for `automake'. make[1]: Leaving directory `/mnt/uc/sources/uClinux-dist/config' . linux-3.x/.config; if [ "$CONFIG_INITRAMFS_SOURCE" != "" ]; then \ mkdir -p `dirname $CONFIG_INITRAMFS_SOURCE`; \ touch $CONFIG_INITRAMFS_SOURCE || exit 1; \ fi make ARCH=arm CROSS_COMPILE=arm-linux- CFLAGS_KERNEL="" AFLAGS_KERNEL="" EXTRA_MODULE_DIRS="" -j8 -C linux-3.x || exit 1 make[1]: Entering directory `/mnt/uc/sources/uClinux-dist/linux-3.x' CHK include/linux/version.h HOSTCC scripts/basic/fixdep CHK include/generated/utsrelease.h HOSTCC scripts/conmakehash CC scripts/mod/empty.o HOSTCC scripts/mod/mk_elfconfig make[2]: `include/generated/mach-types.h' is up to date. CC kernel/bounds.s MKELF scripts/mod/elfconfig.h HOSTCC scripts/mod/file2alias.o HOSTCC scripts/mod/modpost.o HOSTCC scripts/mod/sumversion.o GEN include/generated/bounds.h CC arch/arm/kernel/asm-offsets.s HOSTLD scripts/mod/modpost GEN include/generated/asm-offsets.h CALL scripts/checksyscalls.sh CHK include/generated/compile.h CC init/main.o CC init/do_mounts.o CC init/do_mounts_rd.o HOSTCC usr/gen_init_cpio CC init/do_mounts_initrd.o CC init/initramfs.o CC arch/arm/nwfpe/fpa11.o CC arch/arm/nwfpe/fpa11_cpdo.o CC arch/arm/nwfpe/fpa11_cpdt.o UPD include/generated/compile.h CC arch/arm/kernel/elf.o GEN usr/initramfs_data.cpio AS usr/initramfs_data.o CC arch/arm/nwfpe/fpa11_cprt.o LD usr/built-in.o /mnt/uc/toolchains/arm-linux-tools/usr/local/bin/arm-linux-ld: line 183: /mnt/uc/toolchains/arm-linux-tools/usr/local/bin/arm-linux-ld.real: No such file or directory make[2]: *** [usr/built-in.o] Error 127 make[1]: *** [usr] Error 2
