Was hoping that someone else came across this and has a fix for it ... I followed the instructions at http://code.google.com/p/mini6410-debian/wiki/Tutorial to get my system working. Kernel config config_mini6410_a70 was modified to add support for dm-crypt, and to shut off the initram. System will boot just fine to serial console. When trying to boot with console going to the touchscreen, the penguin logo comes up, the boot messages scroll by, and the kernel gets as far as requesting an IP from the DHCP server, then immediately reboots. This will happen over and over again, until the touchscreen simply stays completely white. Note that when that finally occurs, you can still access a console via serial port, and the system is up and running. This occurs with more than one of the 7" touch screens, so it is not related to the specific piece of hardware. Is there something wrong with the kernel driver for the touchscreen, or does it need to be configured somehow? Is this something that works in a later version of the kernel (i.e. post 2.6.36)? Thanks in advance.
Mini6410/Debian Squeeze: touchscreen causing reboot on boot
this is just a guess, the FA kernel sources use initramfs, which you've disabled, so you're no longer using the /scripts/friendlyarm.cpio in the kernel sources, I know for the mini210 that this file contains all of the touchscreen setup stuff in the 'init' file and adds it to the /dev/ folder.
Thanks, Reggie. Will take a look at that. I had disabled the initramfs for booting from the SD card, but, technically, I am booting from U-Boot in the NAND at this point, so perhaps that is something to look into. I do see touchscreeen and touchscreen1wire in the /dev/ folder already, but maybe there is something that the kernel needs during the startup process in the initrd to make it work right. I had tried this with the stock kernel (mini6410_config_a70) as well, and had gotten the same results, but I had not taken the "noinitrd" out of the kernel boot args. Going to try this now.
There is more, take a look at the /scripts/friendlyarm.cpio file, you should be able to open it in any archive manager, then open up the init file in a text editor, it's all in there what it does :)
Looked into the friendlyarm.cpio file ... I see a couple of nodes for /dev/ that I don't have, but nothing related to the touchscreen. There is also an installation of BusyBox in there; not sure if this is of any use to me since I am running a full Debian install. Also looked at the init file ... looks like there are a couple of configuration files that I am missing out of /etc/, but I have not seen where they come from. Going to poke around and see if I can find them.
This is the contents of the init file in the cpio, there is a distinct
section that starts at the ONE_WIRE_PROC= line that deals specifically with
touchscreens.
Do you have serial console connection to your 6410? If so it might be
useful if you post a log including the errors.
#! /bin/sh
PATH=/sbin:/bin:/usr/sbin:/usr/bin
runlevel=S
prevlevel=N
umask 022
export PATH runlevel prevlevel
# Trap CTRL-C &c only in this shell so we can interrupt subprocesses.
trap ":" INT QUIT TSTP
/bin/hostname FriendlyARM
/bin/mount -n -t proc proc /proc
cmdline=`cat /proc/cmdline`
ROOT=none
ROOTFLAGS=
ROOTFSTYPE=
NFSROOT=
IP=
INIT=/sbin/init
for x in $cmdline ; do
case $x in
root=*)
ROOT=${x#root=}
rootfstype=*)
ROOTFSTYPE="-t ${x#rootfstype=}"
rootflags=*)
ROOTFLAGS="-o ${x#rootflags=}"
init=*)
INIT=${x#init=}
nfsroot=*)
NFSROOT=${x#nfsroot=}
ip=*)
IP=${x#ip=}
esac
done
if [ ! -z $NFSROOT ] ; then
echo $NFSROOT | sed s/:/\ /g > /dev/x ; read sip dir < /dev/x
echo $IP | sed s/:/\ /g > /dev/x; read cip sip2 gip netmask hostname
device autoconf < /dev/x
rm /dev/x
#echo $sip $dir $cip $sip2 $gip $netmask $hostname $device $autoconf
mount -t nfs $NFSROOT /r -o nolock,proto=tcp
#[ -e /r/dev/console ] || exec /bin/sh
elif [ ! -z $run_fs_image ] ; then
ROOTFSTYPE="-t ext3"
for i in 1 2 3 4 5 ; do
/bin/mount -n -o sync -o noatime -o nodiratime -t vfat /dev/mmcblk0p1
/sdcard && break
echo Waiting for SD Card...
sleep 1
done
/sbin/losetup /dev/loop0 /sdcard/$run_fs_image
/bin/mount $ROOTFSTYPE /dev/loop0 /r
mount -o move /sdcard /r/sdcard
#/sbin/losetup /dev/loop1 /r/sdcard/swap
#/sbin/swapon /dev/loop1
else
/bin/mount -n $ROOTFLAGS $ROOTFSTYPE $ROOT /r
fi
ONE_WIRE_PROC=/proc/driver/one-wire-info
ETC_BASE=/r/etc
[ -d /r/system/etc ] && ETC_BASE=/r/system/etc
[ -e $ETC_BASE/ts.detected ] && . $ETC_BASE/ts.detected
[ -z $CHECK_1WIRE ] && CHECK_1WIRE=Y
if [ $CHECK_1WIRE = "Y" -a -e $ONE_WIRE_PROC ] ; then
if read lcd_type fw_ver tail < $ONE_WIRE_PROC ; then
if [ x$lcd_type = "x0" -a x$fw_ver = "x0" ] ; then
TS_DEV=/dev/touchscreen
else
TS_DEV=/dev/touchscreen-1wire
echo "1Wire touchscreen OK"
fi
if [ -e $ETC_BASE/friendlyarm-ts-input.conf ]; then
sed "s:^\(TSLIB_TSDEVICE=\).*:\1$TS_DEV:g"
$ETC_BASE/friendlyarm-ts-input.conf > $ETC_BASE/ts-autodetect.conf
mv $ETC_BASE/ts-autodetect.conf $ETC_BASE/friendlyarm-ts-input.conf
-f
echo "CHECK_1WIRE=N" > $ETC_BASE/ts.detected
sync
fi
fi
fi
[ -e /r/etc/friendlyarm-ts-input.conf ] && .
[ -e /r/system/etc/friendlyarm-ts-input.conf ] && .
export TSLIB_TSDEVICE
#exec /bin/sh
umount /proc
exec switch_root /r $INIT </r/dev/console >/r/dev/console 2>&1
Really no log to post, unfortunately. When it resets, it is in the middle of DHCP negotiation, you see a single "K" appear like it is trying to say "Kernel panic", and the board resets. I don't have any of those configuration files at the moment, but I did find another blog post that mentions pulling them out of the Qt archives that come on the DVDs I got with the board. Going to take a look at that next. Maybe all I need is to get them into place, then make an init script that gets called early to configure the touchscreen like this init does. Will see how it goes.
I would set loglevel=8 in the kernel commandline, you won't have any of those files, do you know which touchscreen driver the a70 is using? If it's 1-wire then you'll need do what that touchscreen section is doing, you'll only need to do it once.
I'm starting to think it's something hardware related at this point ... Noted that the touchscreen apps/conf wasn't loaded from Debian. apt-get'ed the libts-bin and tsconf packages. No friendlyarm-ts-input driver, so grabbed that from the rootfs_qtopia_qt4 tarball that came with the board. Set up an init script to mimic what the initrd is doing. Still doesn't make a difference. For s**ts & grins I decided to re-flash the Qtopia installation onto the NAND and try and eliminate my installation from the equation. The Qtopia install does the same thing as my install. Since the error seems to be happening when the Ethernet port is being brought up, I disconnected the network line. Boots through fine. Connect the line, no problem. Try and bring up eth0 with an address - board reset. So at this point, I'm at a loss as to where to go with this. I'm going to try and get one of the reps at andahammer on the phone and see if they have any suggestions to try. I'm hoping that the NAND is not shot, though there should be no reason for it to be. Will post back when I have some more info. I hope that no one else has had to go through this to customize their board.
Well, as it all seems to live or die around the ethernet, I would start looking at how the networking is setup, maybe turn on debugging in the dm9000 driver? Also look at the standard networking files, perhaps there's something stupid missing? hosts file, hostname, routing etc?
Ok, found the culprit ... wrong power supply. Apparently the Mini2440 uses a different power supply than the Mini6410, and we are looking at both boards right now. When I gathered up the hardware from our recently released developer, he was using the wrong plug; never knew it because he never had the display connected. *facepalm* So .... for anyone else who experiences some oddity like this, make sure you have the right plug. The Mini6410 requires a 5V/2A plug; the Mini2440 uses a 5V/1A plug. The difference in amperage is just enough that when all peripheral devices are connected and online (touchscreen, Ethernet, and USB keyboard), the board pulls just a tad too much power, and everything resets (and when I say a tad too much, I'm talking about the voltage dropping < 0.1V from the 5.0V required to power everything). Reggie, thanks for the help and the time you spent here; it has been greatly appreciated. I'm now off to label the hardware so that I know which blessed plug I'm supposed to use ..... *grumble grumble* :)
William, congratulations and you're welcome. All of the PSU that I have for mini boards are the US 2 prong style plugs, so I have to use the 'travel' plugs you find in £ stores, it's actually very handy as I have to hot-glue the psu to the travel plug, then I write on the side of the plug which board it's for. FYI. I have been running a mini210S from a 5v/1.5a psp charger without issues.
