Hi everyone I have a big problem to configure qtcreator for tiny6410 --------------------------------------------------------------------------- 1 step-> I get the x86-qte-4.6.1-20100201.tar.gz on CD1 extracts and execute script buil-all #/bin/bash rm -fr /opt/qtsdk-2010.01* rm -fr qt-everywhere-opensource-src-4.6.1 rm -fr /usr/local/Trolltech/QtEmbedded-4.6.1-x86 ./qt-sdk-linux-x86-opensource-2010.01.bin cd /opt/qtsdk-2010.01/qt/tools/qvfb/ /opt/qtsdk-2010.01/qt/bin/qmake "QT_SOURCE_TREE=/opt/qtsdk-2010.01/qt" make cd - tar xfvz qt-everywhere-opensource-src-4.6.1.tar.gz cd qt-everywhere-opensource-src-4.6.1 echo yes | ./configure -opensource -embedded x86 -xplatform qws/linux-generic-g++ -qt-libtiff -qt-libmng -qvfb make && make install cd /usr/local/Trolltech/QtEmbedded-4.6.1-i386 --------------------------------------------------------------------------- 2 step-> I get the arm-linux-gcc-4.5.1-v6-vfp-20101103.tgz on CD1 extracts and added the toochain on PATH variable, echo 'export PATH=$PATH:/path-on-toochain/bin' >> ~/.bashrc the toolchain works very well! --------------------------------------------------------------------------- 3 step -> I get the arm-qte-4.7.0-20101105.tar.gz on CD1 extracts and execute script buil-all #/bin/bash rm -fr qt-everywhere-opensource-src-4.7.0 rm -fr /usr/local/Trolltech/QtEmbedded-4.7.0-arm tar xfvz qt-everywhere-opensource-src-4.7.0.tar.gz cd qt-everywhere-opensource-src-4.7.0 echo yes | ./configure -opensource -embedded arm -xplatform qws/linux-arm-g++ -no-webkit -qt-libtiff -qt-libmng -qt-mouse-tslib -qt-mouse-pc -no-mouse-linuxtp -no-neon make && make install cd /usr/local/Trolltech/QtEmbedded-4.7.0-arm --------------------------------------------------------------------------- ERROR --------------------------------------------------------------------------- when I add qmake on the menu tools-> options-> qtversions, I clik rebuild the following error happens: Building debugging helper library in /home/diego/.local/share/data/Nokia/QtCreator/qtc-debugging-helper/120120557/ Running /usr/bin/make distclean... rm -f gdbmacros.o rm -f *~ core *.core rm -f libgdbmacros.so.1.0.0 rm -f libgdbmacros.so libgdbmacros.so.1 libgdbmacros.so.1.0 libgdbmacros.a rm -f Makefile Running /usr/local/Trolltech/QtEmbedded-4.7.0-arm/bin/qmake ... Running /usr/bin/make ... arm-linux-g++ -c -pipe -g -Wall -W -D_REENTRANT -fPIC -DUSE_QT_GUI=1 -DQT_GUI_LIB -DQT_CORE_LIB -DQT_SHARED -I/usr/local/Trolltech/QtEmbedded-4.7.0-arm/mkspecs/qws/linux-arm-g++ -I. -I/usr/local/Trolltech/QtEmbedded-4.7.0-arm/include/QtCore -I/usr/local/Trolltech/QtEmbedded-4.7.0-arm/include/QtGui -I/usr/local/Trolltech/QtEmbedded-4.7.0-arm/include -I. -o gdbmacros.o gdbmacros.cpp make: arm-linux-g++: Command not found make: *** [gdbmacros.o] Error 127 the picture http://www.4shared.com/photo/qbb5jNfa/Screenshot-1.html -------------------------------------------------------------------------- someone could help me with the configuration plz I dont have more ideas of what to do
qtcreator dont work
Dear davef, I using the files on DVD received with the tiny6410 kit, i just run script and add PATH. root@diego# arm-linux-g++ -v Using built-in specs. COLLECT_GCC=arm-linux-g++ COLLECT_LTO_WRAPPER=/home/embedded/opt/FriendlyARM/toolschain/4.5.1/bin/../libex ec/gcc/arm-none-linux-gnueabi/4.5.1/lto-wrapper Target: arm-none-linux-gnueabi Configured with: /work/toolchain/build/src/gcc-4.5.1/configure --build=i686-build_pc-linux-gnu --host=i686-build_pc-linux-gnu --target=arm-none-linux-gnueabi --prefix=/opt/FriendlyARM/toolschain/4.5.1 --with-sysroot=/opt/FriendlyARM/toolschain/4.5.1/arm-none-linux-gnueabi/sys-root --enable-languages=c,c++ --disable-multilib --with-cpu=arm1176jzf-s --with-tune=arm1176jzf-s --with-fpu=vfp --with-float=softfp --with-pkgversion=ctng-1.8.1-FA --with-bugurl=http://www.arm9.net/ --disable-sjlj-exceptions --enable-__cxa_atexit --disable-libmudflap --with-host-libstdcxx='-static-libgcc -Wl,-Bstatic,-lstdc++,-Bdynamic -lm' --with-gmp=/work/toolchain/build/arm-none-linux-gnueabi/build/static --with-mpfr=/work/toolchain/build/arm-none-linux-gnueabi/build/static --with-ppl=/work/toolchain/build/arm-none-linux-gnueabi/build/static --with-cloog=/work/toolchain/build/arm-none-linux-gnueabi/build/static --with-mpc=/work/toolchain/build/arm-none-linux-gnueabi/build/static --with-libelf=/work/toolchain/build/arm-none-linux-gnueabi/build/static --enable-threads=posix --with-local-prefix=/opt/FriendlyARM/toolschain/4.5.1/arm-none-linux-gnueabi/sys -root --disable-nls --enable-symvers=gnu --enable-c99 --enable-long-long Thread model: posix gcc version 4.5.1 (ctng-1.8.1-FA) if this is not the correct way to configure qt and toochain someone could describe how the configuration is done?
I could be wrong here, but doing export only lasts while you are in that particular session. I would try try putting: export PATH=$PATH:/path-on-toochain/bin statement in your script.
