How to setup Qt in Pendutronix BSP?
Brabbit
I would like to compile or setup Qt in Pengutronix BSP.
I choose "ptxconfig.qt" in ptxdist and use "ptxdist menuconfig" select qt
and config everything I want.I choose platform and use "ptxdist go" but it
not work.
I will attach picture.
What happens when you go to that URL manually?
Brabbit
It's not download qt-everywhere-opensource-4.8.4.tar.gz.
Brabbit
Can I use old version then 4.7.0?
Juergen Beisert
No.
> but it not work.
Load the source archive (qt-everywhere-opensource-4.8.4.tar.gz) from a
different web location and store it to the folder, where PTXdist expects it
(usually the src/ directory in your project).
Then continue with the "ptxdist go".
Brabbit
Thank you Juergen Beisert.
I download qt-everywhere-opensource-4.8.4.tar.gz from different web and
copy into folder OSELAS.BSP-Pengutronix-Mini2440-2012.12.0/src.
And then "ptxdist go".But it's download again from qt link.
Juergen Beisert
Hmm, strange. When PTXdist finds the expected archive in your
"/home/best/OSELAS.BSP-Pengutronix-Mini2440-2012.12.0/src/qt-everywhere-ope
nsource-4.8.4.tar.gz"
it should be happy. Are you sure, there is no typo in the name or path?
Brabbit
Oh! I find problem.
It has backspace in file name.
Thank you.
Juergen Beisert
Brabbit
Now. "ptxdist go" is ok.
How to setup Qt in pengutronix BSP?
Brabbit
Can I copy qt-everywhere-opensource-src-4.8.4-build into filesystem in SD
Card?
Juergen Beisert
Can you explain what you want to do? If you want to configure Qt's features
for your target just run "ptxdist menuconfig" -> Graphics & Multimedia ->
qt and enable or disable all optional features.
After the "ptxdist go" is finished you can deploy your target with the
result and all required components are part of the target's root
filesystem.
> filesystem in SD Card?
Once again: what do you want to do?
Brabbit
I want to run Qt application on Mini2440.
Juergen Beisert
I guess now: you want to develop your own Qt based applications.
PTXdist supports qmake based projects, so you should be able to develop
your own Qt apps, while PTXdist ensures your own programs and the root
filesystem of your target are consistent.
Happy hacking.
Brabbit
Thank you.Juergen Beisert
I have new problem for compile qt-everywhere-opensource-src-4.8.4.
I use :
sudo ./configure -embedded arm -prefix /usr/local/Qt4.8.4 -xplatform
qws/linux-arm-g++ -qt-mouse-tslib -qt-kbd-linuxinput -qt-gfx-linuxfb
-no-glib -no-qt3support -no-largefile
to compile qt4.8.4 and then "make"
It's show as picture in attachment.
I don't have bootstrap in directory
'/home/best/qt4.8/qt-everywhere-opensource-src-4.8.4/src/tools/bootstrap'
Juergen Beisert
Attaching screen shots are for the windows people. You can copy the content
from the console and paste it into your message.
Brabbit
Qt is now configured for building. Just run 'make'.
Once everything is built, you must run 'make install'.
Qt will be installed into /usr/local/Qt4.8.4
To reconfigure, run 'make confclean' and 'configure'.
best@best-Inspiron-N5010:~/qt4.8/qt-everywhere-opensource-src-4.8.4$ make
cd src/tools/bootstrap/ && make -f Makefile
make[1]: Entering directory
`/home/best/qt4.8/qt-everywhere-opensource-src-4.8.4/src/tools/bootstrap'
g++ -c -pipe -fno-exceptions -O2 -fPIC -Wall -W -DQT_BOOTSTRAPPED
-DQT_LITE_UNICODE -DQT_NO_CAST_FROM_ASCII -DQT_NO_CAST_TO_ASCII
-DQT_NO_CODECS -DQT_NO_DATASTREAM -DQT_NO_GEOM_VARIANT -DQT_NO_LIBRARY
-DQT_NO_QOBJECT -DQT_NO_STL -DQT_NO_SYSTEMLOCALE -DQT_NO_TEXTSTREAM
-DQT_NO_THREAD -DQT_NO_UNICODETABLES -DQT_NO_USING_NAMESPACE
-DQT_NO_DEPRECATED -I../../../mkspecs/qws/linux-x86-g++ -I.
-I../../../include -I../../../include/QtCore -I../../../include/QtXml
-I../../3rdparty/zlib -o .obj/release-static-emb-arm/qisciicodec.o
../../corelib/codecs/qisciicodec.cpp
Assembler messages:
Fatal error: can't create .obj/release-static-emb-arm/qisciicodec.o:
Permission denied
make[1]: *** [.obj/release-static-emb-arm/qisciicodec.o] Error 2
make[1]: Leaving directory
make: *** [sub-tools-bootstrap-make_default-ordered] Error 2
It's content from my console.
