I would like to advice me to compile this application of Ekiga on mini2440 with arm ARCH. Thank you in advance for your help.
Help to compile Ekiga
Thank you for your quick reply, but would you please advice me if there ara any forum or documents which would help me .
http://buildroot.uclibc.org/ and links
Purpose: Compile the "ekiga» application with a Linux kernel for a mini2440 Compilation procedure 1- Add the ekiga appilication in the Buildroot Link "http://www.linuxembedded.fr/2011/03/ajouter-un-package-dans-buildroot-en...; 2- Compiling Linux kernel with buildroot Link "http://www.linuxembedded.fr/2013/02/tutorial-un-systeme-linux-embarque-o...; In the output/Image there are the following files: rootfs.tar, rootfs.jffs2, u-boot.bin, uImage 3- I installed the bootloader u-boot in the card’s nand memory 4- I installed rootfs.jffs2 5- I installed the kernel by using the tftp command Thank you in advance for your help. Result: Nothing is functional
Try a "hello world" application in your build environment first. The Linux journey can be, frustrating at times, but even more rewarding when you succeed. Keep trying. Sorry I cannot give more advice. I built the Ekiga application for the Mini6410 using openembedded.
Thank you for your reply, Would you please give me step by step the compilation procedure of the 'Ekiga' application for the mini6410 with openembedded. i'm totally blocked with the mini2440. i.e: 'Hello Word' was compiled with success unlike 'Ekiga' thank you in advance.
Hi There is a tutorial for openembedded and the Mini2440 at: http://billforums.station51.net/ Once you have your system up and running you would simply: bitbake ekiga Good luck!
