h i am new to mini2440... when i am trying to set up cross compile environment with linux mint.... i am unable to make my installed tool chain to store in "/usr/local/arm" here i am mentioning th steps i followed... 1. i copied arm-linux-gcc.4.4.3.tgz fine into /tmp 2. i enetered the command tar xvzf arm-linux-gcc.4.4.3.tgz -C / but still my installed file "FriendlyArm" is storing into /tmp/opt instead of in the expecting directory /usr/local/arm actually if i dont give "-C /" in the command mentioned in step 2 then this might be happen.....but even though i am adding "-C /" at the end of my command still it is storing in /tmp/opt. and i am unable to copy the installed file from "/tmp/opt" to "/usr/local/arm" can any one please tell me how to make my installed file tobe stored in "usr/local/arm" path. Note: here the inverted quotes are mentioned just for convenience, they are not the part of commands. Thank you
CROSS COMPILE SETUP PROBLEM
Personally, I would not use /tmp. I normally just place the .tgz file in /home or home/tmp > 2. i enetered the command tar xvzf arm-linux-gcc.4.4.3.tgz -C / wouldn't you have to say tar xvzf arm-linux-gcc.4.4.3.tgz -C /usr/local/arm You might have to make that directory first.
