Hi all! I have got a FriendlyARM Tiny210v2 KIT.I want to use AV IN port.Now,I install media-ctl but some error when make. On PC install Ubuntu11.10,I configure step by step: [code] $ sudo apt-get install autoconf libtool $ cd <Absolute Path to your media-ctl directory> For the below two steps, you can use whatever tool chain you need $ export CC=/opt/FriendlyARM/toolschain/arm/bin/arm-none-linux-gnueabi-gcc $ export CPP=/opt/FriendlyARM/toolschain/arm/bin/arm-none-linux-gnueabi-cpp $ autoreconf --install $ ./configure --with-kernel-headers=/usr/src/linux-headers-3.0.0-12-generic/include --build=arm --host=i686 --prefix=opt/media kernel headers path is where we installed kernel headers during kernel compilation. And to know the hosttype please give "echo $HOSTTYPE" command . $ make $ make install [/code] But errors exist at make command [code] root@ubuntu:~/media-ctl-b16cbe7# ls configure.in debian libmediactl.pc.in m4 src COPYING.GPL INSTALL libv4l2subdev.pc.in Makefile.am root@ubuntu:~/media-ctl-b16cbe7# autoconf --install autoconf: error: invalid option `--install' Try `autoconf --help' for more information. root@ubuntu:~/media-ctl-b16cbe7# autoreconf --install libtoolize: putting auxiliary files in AC_CONFIG_AUX_DIR, `config'. libtoolize: copying file `config/config.guess' libtoolize: copying file `config/config.sub' libtoolize: copying file `config/install-sh' libtoolize: copying file `config/ltmain.sh' libtoolize: putting macros in AC_CONFIG_MACRO_DIR, `m4'. libtoolize: copying file `m4/libtool.m4' libtoolize: copying file `m4/ltoptions.m4' libtoolize: copying file `m4/ltsugar.m4' libtoolize: copying file `m4/ltversion.m4' libtoolize: copying file `m4/lt~obsolete.m4' configure.in:8: installing `config/missing' src/Makefile.am: installing `config/depcomp' root@ubuntu:~/media-ctl-b16cbe7# sudo PATH=/opt/FriendlyARM/toolschain/4.4.3/bin:$PATH ./configure --with-kernel-headers=/lib/modules/3.0.0-12-generic/build/include --build=arm --host=i686 --prefix=/opt/media checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for i686-strip... no checking for strip... strip configure: WARNING: using cross tools not prefixed with host triplet checking for a thread-safe mkdir -p... /bin/mkdir -p checking for gawk... no checking for mawk... mawk checking whether make sets $(MAKE)... yes checking for i686-gcc... no checking for gcc... gcc checking whether the C compiler works... yes checking for C compiler default output file name... a.out checking for suffix of executables... checking whether we are cross compiling... yes checking for suffix of object files... o checking whether we are using the GNU C compiler... yes checking whether gcc accepts -g... yes checking for gcc option to accept ISO C89... none needed checking for style of include used by make... GNU checking dependency style of gcc... gcc3 checking build system type... arm-unknown-none checking host system type... i686-pc-none checking how to print strings... printf checking for a sed that does not truncate output... /bin/sed checking for grep that handles long lines and -e... /bin/grep checking for egrep... /bin/grep -E checking for fgrep... /bin/grep -F checking for ld used by gcc... /usr/bin/ld checking if the linker (/usr/bin/ld) is GNU ld... yes checking for BSD- or MS-compatible name lister (nm)... no checking for i686-dumpbin... no checking for i686-link... no checking for dumpbin... no checking for link... link -dump checking the name lister (nm) interface... BSD nm checking whether ln -s works... yes checking the maximum length of command line arguments... 1572864 checking whether the shell understands some XSI constructs... yes checking whether the shell understands "+="... yes checking how to convert arm-unknown-none file names to i686-pc-none format... func_convert_file_noop checking how to convert arm-unknown-none file names to toolchain format... func_convert_file_noop checking for /usr/bin/ld option to reload object files... -r checking for i686-objdump... no checking for objdump... objdump checking how to recognize dependent libraries... unknown checking for i686-dlltool... no checking for dlltool... no checking how to associate runtime and link libraries... printf %s\n checking for i686-ar... no checking for ar... ar checking for archiver @FILE support... @ checking for i686-strip... strip checking for i686-ranlib... no checking for ranlib... ranlib checking command to parse nm output from gcc object... ok checking for sysroot... no checking for i686-mt... no checking for mt... mt checking if mt is a manifest tool... no checking how to run the C preprocessor... gcc -E checking for ANSI C header files... yes checking for sys/types.h... yes checking for sys/stat.h... yes checking for stdlib.h... yes checking for string.h... yes checking for memory.h... yes checking for strings.h... yes checking for inttypes.h... yes checking for stdint.h... yes checking for unistd.h... yes checking for dlfcn.h... yes checking for objdir... .libs checking if gcc supports -fno-rtti -fno-exceptions... no checking for gcc option to produce PIC... -fPIC -DPIC checking if gcc PIC flag -fPIC -DPIC works... yes checking if gcc static flag -static works... yes checking if gcc supports -c -o file.o... yes checking if gcc supports -c -o file.o... (cached) yes checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes checking whether -lc should be explicitly linked in... no checking dynamic linker characteristics... no checking how to hardcode library paths into programs... immediate checking whether stripping libraries is possible... yes checking if libtool supports shared libraries... no checking whether to build shared libraries... no checking whether to build static libraries... yes checking linux/media.h usability... yes checking linux/media.h presence... yes checking for linux/media.h... yes checking linux/types.h usability... yes checking linux/types.h presence... yes checking for linux/types.h... yes checking linux/v4l2-mediabus.h usability... yes checking linux/v4l2-mediabus.h presence... yes checking for linux/v4l2-mediabus.h... yes checking linux/v4l2-subdev.h usability... yes checking linux/v4l2-subdev.h presence... yes checking for linux/v4l2-subdev.h... yes checking linux/videodev2.h usability... yes checking linux/videodev2.h presence... yes checking for linux/videodev2.h... yes checking fcntl.h usability... yes checking fcntl.h presence... yes checking for fcntl.h... yes checking for stdlib.h... (cached) yes checking for string.h... (cached) yes checking sys/ioctl.h usability... yes checking sys/ioctl.h presence... yes checking for sys/ioctl.h... yes checking sys/time.h usability... yes checking sys/time.h presence... yes checking for sys/time.h... yes checking for unistd.h... (cached) yes checking for inline... inline checking for size_t... yes checking for struct stat.st_rdev... yes checking whether sys/types.h defines makedev... yes checking for stdlib.h... (cached) yes checking for GNU libc compatible malloc... no checking for stdlib.h... (cached) yes checking for GNU libc compatible realloc... no checking for memset... yes checking for strerror... yes checking for strrchr... yes checking for strtoul... yes configure: creating ./config.status config.status: creating Makefile config.status: creating src/Makefile config.status: creating libmediactl.pc config.status: creating libv4l2subdev.pc config.status: creating config.h config.status: executing depfiles commands config.status: executing libtool commands root@ubuntu:~/media-ctl-b16cbe7# sudo PATH=/opt/FriendlyARM/toolschain/4.4.3/bin:$PATH make make all-recursive make[1]: Entering directory `/root/media-ctl-b16cbe7' Making all in src make[2]: Entering directory `/root/media-ctl-b16cbe7/src' /bin/bash ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I.. -I/lib/modules/3.0.0-12-generic/build/include/include -g -O2 -MT media.lo -MD -MP -MF .deps/media.Tpo -c -o media.lo media.c libtool: compile: gcc -DHAVE_CONFIG_H -I. -I.. -I/lib/modules/3.0.0-12-generic/build/include/include -g -O2 -MT media.lo -MD -MP -MF .deps/media.Tpo -c media.c -o media.o In file included from media.c:34:0: media.h: In function 'media_entity_type': media.h:103:29: error: 'MEDIA_ENTITY_TYPE_MASK' undeclared (first use in this function) media.h:103:29: note: each undeclared identifier is reported only once for each function it appears in media.c: In function 'media_entity_remote_source': media.c:41:21: error: 'MEDIA_PAD_FLAG_INPUT' undeclared (first use in this function) media.c:47:23: error: 'MEDIA_LINK_FLAG_ENABLED' undeclared (first use in this function) media.c: In function 'media_setup_link': media.c:115:23: error: 'MEDIA_PAD_FLAG_OUTPUT' undeclared (first use in this function) media.c:120:21: error: 'MEDIA_PAD_FLAG_INPUT' undeclared (first use in this function) media.c:122:39: error: 'MEDIA_LINK_FLAG_IMMUTABLE' undeclared (first use in this function) media.c: In function 'media_reset_links': media.c:147:22: error: 'MEDIA_LINK_FLAG_IMMUTABLE' undeclared (first use in this function) media.c:152:28: error: 'MEDIA_LINK_FLAG_ENABLED' undeclared (first use in this function) media.c: In function 'media_enum_entities': media.c:267:26: error: 'MEDIA_ENTITY_ID_FLAG_NEXT' undeclared (first use in this function) media.c:290:36: error: 'MEDIA_ENTITY_TYPE_DEVNODE' undeclared (first use in this function) media.c:291:36: error: 'MEDIA_ENTITY_TYPE_V4L2_SUBDEV' undeclared (first use in this function) make[2]: *** [media.lo] Error 1 make[2]: Leaving directory `/root/media-ctl-b16cbe7/src' make[1]: *** [all-recursive] Error 1 make[...stripped-down
