What is the effect of bad sectors when loading an image
Rafael
The DNW application can be used to upload and download images of the
Mini2440's entire NAND flash.
You can backup the NAND flash of Board-A to your computer and put that
image on another Mini2440 Board-B that will act as a clone of the first
one.
I assume Board-A will cater for bad sectors on its own flash. Board-B will
not have bad sectors at the same places as Board-A. Will simply cloning the
NAND flash with an image create the possibility that important files might
overlap with bad sectors on Board-B?
