Hi. Everyone. I've a problem with Pengutronix BSP. I repeat this PDF file : http://www.oselas.org/oselas/bsp/pengutronix/download/OSELAS.BSP-Pengutr... In section 3.2.3 I use command "./configure" but it error and show this "checking awk version... configure: error: we need GNU awk" I need you help for fix this error. Thank you.
Have a problem with Pengutronix BSP
"error: we need GNU awk" Install the GNU awk tool. How to do this, depends on your used distribution.
Hi. Today I've a new problem to build the root filesystem. At Section 4.6 in PDF file. I use command "ptxdist go" but it error and show this : ptxdist: error: toolchain doesn't point to an OSELAS.Toolchain ptxdist: error: leave PTXCONF_CROSSCHAIN_VENDOR empty to disable vendor check please help me. How I can fix it. Thank you.
Did you already build the OSELAS.Toolchain? It is also described in section 3.3.2 of the PDF as one important part to get a working environment. In the "ptxdist platform <your platform>" (section 4.4) PTXdist should detect an existing OSELAS.Toolchain, if not, you can do it manually (section 4.5).
@Juergen Beisert thank you. But now. In section 4.7 I use command "ptxdist platformconfig" and choose "image creation option". I choose image types: hd.img root.jffs2 uRamdisk root.ext2 root.squashfs root.tgz root.ubi but it has not initrd.gz in choice. What should I do?
In page 27 in PDF file. I use command ping from mini2440 to my host PC. It's Ok. But I can't ping from my host PC to mini2440. 2)How I use tftp transfer barebox-image to mini2440?
That's is normal. 2) see other post Your previous post: I never changed this option from what must be the default (root.jffs2)
hi. I am newbie in friendlyarm and I want to install Pengutronix. But I don't know where to start my work. I've read the Pengutronix manual but I couldnt understand what it say. Please help me to install it in an easier way. thanks
The Pengutronix BSP goes on your host. If you can't work out how to do it from the manual I suspect you will have many more problems. Are you having to translate the manual into another language? This BSP is supplied free to the mini2440 community.
I second what davef has said. First you should get more experience about computer programming, especially embedded programming and cross compiling (what these words means, how to do so and so on). And then you can continue working with my board support package. And sorry: I will never provide video about it. Because it wouldn't help.
hey i followed http://www.oselas.org/oselas/bsp/pengutronix/download/OSELAS.BSP-Pengutr... i tried "Building the Root Filesystem" when i type ptxdist go i'm getting error like below ptxdist: error: toolchain doesn't point to an OSELAS.Toolchain ptxdist: error: leave PTXCONF_CROSSCHAIN_VENDOR empty to disable vendor check plz give me some solution
I am getting this error, while building the bsp, any help !! nilkantha@nilkantha-Inspiron-N5110:~/mini-linux-3.8.13/OSELAS.BSP-Pengutronix-Mi ni2440-2013.10.0$ ptxdist go ----------------------------- target: barebox.targetinstall ----------------------------- install_init: preparing for image creation of 'barebox'... install_init: @ARCH@ -> armel install_init: @PACKAGE@ -> barebox install_init: @VERSION@ -> 2011.05.0 install_init: @DEPENDS@ -> install_init: preinst not available install_init: postinst not available install_init: prerm not available install_init: postrm not available install_fixup: @PRIORITY@ -> optional ... done. install_fixup: @SECTION@ -> base ... done. install_fixup: @AUTHOR@ -> "Robert Schwebel <r.schwebel\@pengutronix.de>" ... done. install_fixup: @DESCRIPTION@ -> missing ... done. xpkg_finish: collecting license (GPLv2) ... done. xpkg_finish: creating ipkg package ... No suitable file '/usr/bin/bareboxenv' could be found in any of these locations: /home/nilkantha/mini-linux-3.8.13/OSELAS.BSP-Pengutronix-Mini2440-2013.10.0/plat form-mini2440/build-target/barebox-2011.05.0/scripts/bareboxenv-target.mini2440 /home/nilkantha/mini-linux-3.8.13/OSELAS.BSP-Pengutronix-Mini2440-2013.10.0/plat form-mini2440/build-target/barebox-2011.05.0/scripts/bareboxenv-target install file: src=OSELAS.BSP-Pengutronix-Mini2440-2013.10.0/platform-mini2440/build-target/bar ebox-2011.05.0/scripts/bareboxenv-target dst=/usr/bin/bareboxenv owner=0 group=0 permissions=0755 Error: file not found: /home/nilkantha/mini-linux-3.8.13/OSELAS.BSP-Pengutronix-Mini2440-2013.10.0/plat form-mini2440/build-target/barebox-2011.05.0/scripts/bareboxenv-target Error: install_file failed! failed make: *** [/home/nilkantha/mini-linux-3.8.13/OSELAS.BSP-Pengutronix-Mini2440-2013.10.0/pla tform-mini2440/state/barebox.targetinstall] Error 1 nilkantha@nilkantha-Inspiron-N5110:~/mini-linux-3.8.13/OSELAS.BSP-Pengutronix-Mi ni2440-2013.10.0$
The guru should be back soon :) I am running 2013.10.0 with no problems. No suitable file '/usr/bin/bareboxenv' could be found in any of these locations: ... don't understand this warning. There is a bareboxenv in the scripts directory. Have you got that file in there? 16765 bytes.
> The guru should be back soon :) Thanks Dave :)) > missing /usr/bin/bareboxenv Hmm, did you enable ptxdist platformconfig bootloaders ---> [*] barebox ---> [ ] install 'bareboxenv' <--- ???? It shouldn't be selected, because the Barebox bootloader included in the BSP is an older one and does not provide this tool. Deselect it and continue to build the BSP Happy hacking
Good day. So I get that bareboxenv won't work with this BSP which is unfortunate since I am looking for an equivalent to the "fw_setenv" command (in uboot). Specifically I need to modify the bootargs variable from user space...are there other tools I could use to do this ? Thanks !
Was going to suggest following this link to their mailing list but it appears to be dead. http://www.barebox.org/ There was a bit of traffic on Barebox here: http://blog.gmane.org/gmane.comp.embedded.ptxdist.oselas.community Good luck!
Hi, @@davef: the Barebox mailing list isn't dead. The project is still under high development. @marcb: build a different (e.g. more recent) Barebox and take its bareboxenv tool. Not tested, but it should do the job.
In section 3.2.3 of OSELAS BSP i have configure i didn't fget any error but when i try for make utility it say "make: *** No targets specified and no makefile found. Stop." help me with this issue.
Have you got all the necessary tools on your host? Unfortunately, the Quickstart guide doesn't tell you. I guess anyone compiling a kernel would know, but I struggled a bit with this too. The list is in another location, but the one I think causes that error might be: build-essentail or build-essentials So, on the host sudo apt-get install build- ... There are others libncurses-dev? bison flex Good luck!
I have solved the issue make but i got one more problem i'm bit confused while section 3.3 where we have to install cross compiler but i don't know how to do it 1-> what if i install OSELAS.Toolchain it will do the job or i have install a new cross compiler
Section 4.6 of building Root file system unable to sort this issue any suggestion got error in server response. ----------------------------- target: libmad-0.15.1b.tar.gz ----------------------------- --2015-02-16 14:44:35-- ftp://ftp.mars.org/pub/mpeg/libmad-0.15.1b.tar.gz => '/home/ism148/OSELAS.Toolchain-2014.12.0/OSELAS.BSP-Pengutronix-Mini2440/src/lib mad-0.15.1b.tar.gz.5R6yGYmuSe' Resolving ftp.mars.org (ftp.mars.org)... 216.75.62.3, 2001:470:8398:1:5054:ff:fedb:a9f5 Connecting to ftp.mars.org (ftp.mars.org)|216.75.62.3|:21... connected. Logging in as anonymous ... Error in server response, closing control connection. Retrying. Any suggestion how to sort out this issue
I have downloaded the libmad file from another source & copied int local_src folder. after this shall i pass the command ptxdist go or can i skip this part directly jump creating images.(sorry for all this but i'm a greenhorn)
i have copied total tar file in local_src is it correct way to do if not can guide me how to do it $ptxdist -ji2 go ----------------------------- target: libmad-0.15.1b.tar.gz ----------------------------- --2015-02-16 14:44:35-- ftp://ftp.mars.org/pub/mpeg/libmad-0.15.1b.tar.gz => '/home/ism148/OSELAS.Toolchain-2014.12.0/OSELAS.BSP-Pengutronix-Mini2440/src/lib mad-0.15.1b.tar.gz.5R6yGYmuSe' Resolving ftp.mars.org (ftp.mars.org)... 216.75.62.3, 2001:470:8398:1:5054:ff:fedb:a9f5 Connecting to ftp.mars.org (ftp.mars.org)|216.75.62.3|:21... connected. Logging in as anonymous ... Error in server response, closing control connection. Retrying.
sorry but i don't know where to see that file i have searched all directories but didn't find PTXdist/all_src. please can you suggest where to look up
There is a PTXdist directory in my home/davef directory. Going back to 3.2.4 and using the ptxdist setup command, you have the option of specifying a place to put a PTXdist/all_src directory. I have so much stuff in there that I thought it happened automagically. I haven't changed much in my setup for a year or more, my brain doesn't work like it use to and it will soon be midnight here. CU tmw.
Ganesh, PTXdist tries to download the archive into "'/home/ism148/OSELAS.Toolchain-2014.12.0/OSELAS.BSP-Pengutronix-Mini2440/src'" (please read the output carefully you posted above). So, copy your manually downloaded archive into this directory, or - better - define a global (e.g. shared) archive directory as Dave already mentioned and copy the archive into it.
Hi Juergen, I have followed what you have as well as davef said. i have copied all necessary tar file in src and shooted ptxdist go command after that i have got again error. It seem something is missing. target: host-u-boot-tools.compile --------------------------------- make[1]: Entering directory `/home/ism148/OSELAS.Toolchain-2014.12.0/OSELAS.BSP-Pengutronix-Mini2440/platfor m-mini2440/build-host/u-boot-2014.07' Configuring for sandbox board... GEN include/autoconf.mk.dep GEN include/autoconf.mk make[2]: sdl-config: Command not found make[2]: sdl-config: Command not found CHK include/config/uboot.release make[2]: sdl-config: Command not found CHK include/generated/timestamp_autogenerated.h UPD include/config/uboot.release UPD include/generated/timestamp_autogenerated.h make[2]: sdl-config: Command not found HOSTCC scripts/basic/fixdep make[2]: sdl-config: Command not found CHK include/generated/version_autogenerated.h UPD include/generated/version_autogenerated.h make[2]: sdl-config: Command not found CC lib/asm-offsets.s GEN include/generated/generic-asm-offsets.h make[2]: sdl-config: Command not found HOSTCC tools/img2srec HOSTCC tools/aisimage.o In file included from tools/aisimage.c:10:0: include/image.h:851:27: fatal error: openssl/evp.h: No such file or directory # include <openssl/evp.h> ^ compilation terminated. HOSTCC tools/atmelimage.o In file included from tools/atmelimage.c:11:0: include/image.h:851:27: fatal error: openssl/evp.h: No such file or directory # include <openssl/evp.h> ^ compilation terminated. make[3]: *** [tools/aisimage.o] Error 1 make[3]: *** Waiting for unfinished jobs.... make[3]: *** [tools/atmelimage.o] Error 1 make[1]: Leaving directory `/home/ism148/OSELAS.Toolchain-2014.12.0/OSELAS.BSP-Pengutronix-Mini2440/platfor m-mini2440/build-host/u-boot-2014.07' make[2]: *** [tools] Error 2 make[1]: *** [build-one-by-one] Error 2 make: *** [/home/ism148/OSELAS.Toolchain-2014.12.0/OSELAS.BSP-Pengutronix-Mini2440/platfor m-mini2440/state/host-u-boot-tools.compile] Error 2
I'm getting this i have set my ip address differently but i got this mini2440:/ update -t barebox -d nand phy0: Link is up - 100/Full T DHCP client bound to address 192.168.2.35 after this i have changed s2 switch from NOR to NAND and tun off-on s1. and it is giving me this output �load Image of Linux...Uncompressing Linux........................................................................... ........................... invalid compressed format (err=1) -- System halted�load Image of Linux...Uncompressing Linux........................................................................... ..........
So, you are at the top of page 37. > phy0: Link is up - 100/Full > T DHCP client bound to address 192.168.2.35 I have never had these two lines. Perhaps because I never enabled DHCP in Barebox I think you should get: T T T T T ... until tftp has finished. It looks to me that it tries to download it using tftp then falls-back to the Ethernet. You might have to post your boot messages.
