when i am trying to transfer vboot.bin via usbpush i am getting error: Unable to claim usb interface 1 of device: could not claim interface 0: Device or resource busy plz help me .. Thank you
hi, i am using mico2440sdk to port linux 2.6.32 . while i am using usbpush its displaying following error. sudo ./usbpush zImage 0x30008000 Unable to claim usb interface 1 of device: could not claim interface 0: Device or resource busy
If you are not able to run the usbpush in root mode then just try to connect to other ports. It is because the code is just trying to access only the first two ports 0 and 1 only and you may have connected the usb 3rd port !
Hi guyz I am still getting ths error will trying to transfer the uboot to mini2440. I do it as root as well tried different ports but still no use here is my lsusb output renupapa@renupapa-Lenovo-IdeaPad-Z510:~/Desktop/Friendly_Arm/USBPush$ lsusb Bus 002 Device 002: ID 8087:8000 Intel Corp. Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 002: ID 8087:8008 Intel Corp. Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 003 Device 006: ID 0cf3:3004 Atheros Communications, Inc. Bus 003 Device 096: ID 5345:1234 Owon PDS6062T Oscilloscope Bus 003 Device 002: ID 5986:029d Acer, Inc Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub please help me in fixing this....muy USB port lies in BUS 003 ,id tis the problem...if so where in code I should change to make it work Tanks in advance, Cheers
