we have a program .bin. We are able to make uImage using mkimage. Will uboot take this up and boot from there? I am not using mmc; using only the flash in kit Micro 2440 NAND 256MB. Any suggestions on how to go about it is appreciated. Does the already existing supervivi help in making the program work when the kit is switched on? I am asking this because we have to do " download and run" option in dnw (on Windows XP) to see the program run on the kit. Is there any solution to make it permanent download and run at the boot time? Just like the linux that runs on NAND flash? Kindly provide with suggestions. Thank you
Creating a stand alone program on FriendlyARM how to do ??
I have installed uboot in the kit and then trying to put uimage in there that uboot can take up to load. uboot is already installed and 0x30000000 address I tell mkimage with load address 0x32000000 entry point 0x32001000 got my uImage I go back to minicom and press q i get to supervivi shell i tell it to load flash 0x32000000 907516 (907516 is my uImage size) i use usbpush and send my uImage it says downloaded file at 0x30000000 --why so--? I had mentioned start addr as 0x32000000 for uImage -- then it says "failed" --suggest some solutions please--
Unless you have a reason why the three different addresses" 0x30000000 0x32000000 0x32001000 Have a look at this: http://forrestbao.blogspot.co.nz/2008/01/deploying-embedded-linux-to-sam... ... and maybe settle for one address 0x31000000 Be aware you need a u-boot version that will work with 256M as the erase block size is bigger than the 64M variant.
Thanks for the link davef I have followed the steps mentioned except for the file system "jffs". i am not putting a complete kernel but only a small binary file that otherwise works with the NOR mode in the friendlyARM kit. This binary i have transformed to uImage as per the guidelines mentioned. I have used only one address 0x31000000 everywhere. In fact I was surprised to see my values matching exactly with that mentioned in the link provided above. I do not have mmc and take my uimage to ram; load ram 0x31000000 size and put uimage. I skipped the filesystem part and put the uImage in nand write.e kernel space. My uboot (again) loads perfectly and says that uImage format is wrong/ unknown type. and so on. ___________________________________________ The terminal response is as follows :- _________________________________________ U-Boot 1.3.2-mini2440 (Feb 24 2010 - 13:04:49) I2C: ready DRAM: 64 MB Flash: 2 MB NAND: Bad block table not found for chip 0 Bad block table not found for chip 0 256 MiB Found Environment offset in OOB.. USB: S3C2410 USB Deviced In: serial Out: serial Err: serial MAC: 08:08:11:18:12:27 Hit any key to stop autoboot: 0 Loading from NAND 256MiB 3,3V 8-bit, offset 0x60000 ** Unknown image type Wrong Image Format for bootm command ERROR: can't get kernel image! _________________________________ Is my uImage creation wrong? this is the mkimage command i did. mkimage -A arm -O linux -T kernel -C none -a 0x31000000 -d ./2440test.bin uImage _______________________ thanks in advance for advices and suggestions
sudo ./uboot/mini2440/tools/mkimage –A arm –O linux -T kernel -C none –a 0x30008000 –e 0x30008000 -d kernel-bin/arch/arm/boot/zImage output/uImage There is a link on the Downloads page to the Wiki and a tutorial I wrote years ago (which probably has errors) but there is the above line, which might help. Your syntax looks quite different. You appear to be doing something I am not familiar with, ie not loading a Linux kernel into the kernel partition. Maybe, mkimage adds some header information that u-boot doesn't recognise. Can you load a known working kernel?
