Hi all. I'm Diep.I have got a frienlyARM tiny 210v2 KIT.I have installed Qtopia in zImage.When it's done,I connect Webcam usb to KIT.I run Camera usb application in Friendly Tab.It's working :D.On PC installed Ubuntu 11.10,I use Gftp to KIT.I find to Path /dev/video3 (on KIT).I want to copy video3 file but i cannot. I think this file is using.I edit file .rcS (int /etc/init.d..).I did disable line Load Qtopia by add ' # ".Save it. After I reboot KIT.On PC I use Gftp to KIT.I again find to /dev/video3. But amazing,video3 file disappeared.I'm very worry,and edit again .rcS file permit Load Qtopia and reboot.... Login KIT.I find /dev/video3 but it is realy disappear! Can you help me fix this problem! Why does video3 disappear?
File /dev/video3 disappears !!!
It's my .rcS when i edit deny Load Qtopia [code] #! /bin/sh PATH=/sbin:/bin:/usr/sbin:/usr/bin:/usr/local/bin: runlevel=S prevlevel=N umask 022 export PATH runlevel prevlevel # # Trap CTRL-C &c only in this shell so we can interrupt subprocesses. # trap ":" INT QUIT TSTP /bin/hostname FriendlyARM [ -e /proc/1 ] || /bin/mount -n -t proc none /proc [ -e /sys/class ] || /bin/mount -n -t sysfs none /sys [ -e /dev/tty ] || /bin/mount -t ramfs none /dev /bin/mount -n -t usbfs none /proc/bus/usb echo /sbin/mdev > /proc/sys/kernel/hotplug /sbin/mdev -s /bin/hotplug # mounting file system specified in /etc/fstab mkdir -p /dev/pts mkdir -p /dev/shm /bin/mount -n -t devpts none /dev/pts -o mode=0622 /bin/mount -n -t tmpfs tmpfs /dev/shm /bin/mount -n -t ramfs none /tmp /bin/mount -n -t ramfs none /var mkdir -p /var/empty mkdir -p /var/log mkdir -p /var/lock mkdir -p /var/run mkdir -p /var/tmp /sbin/hwclock -s syslogd /etc/rc.d/init.d/netd start echo " " > /dev/tty1 echo "Starting networking..." > /dev/tty1 sleep 1 /etc/rc.d/init.d/httpd start echo " " > /dev/tty1 echo "Starting web server..." > /dev/tty1 sleep 1 #/etc/rc.d/init.d/leds start #echo " " > /dev/tty1 #echo "Starting leds service..." > /dev/tty1 #echo " " #sleep 1 echo " " > /dev/tty1 /etc/rc.d/init.d/alsaconf start echo "Loading sound card config..." > /dev/tty1 echo " " # install additional modules modprobe ft5x06_ts 2>/dev/null modprobe goodix_touch 2>/dev/null modprobe ov9650 2>/dev/null modprobe tvp5150_tiny210 2>/dev/null modprobe rtl8192cu 2>/dev/null /sbin/ifconfig lo 127.0.0.1 /etc/init.d/ifconfig-eth0 fa-network-service hdmi-service autostart # /opt/360box/apktools-service # /opt/360box/run.sh & #/bin/qtopia & echo " " > /dev/tty1 echo "Starting Qtopia or MyApp, please waiting..." > /dev/tty1 sleep 1 [/code]
OK. In an early mini2440 rcS /etc was bound to /tmpfs so that it was volatile. IE, it did not retain any changes made to it. Are you using a SD card? You might have to do a sync after making changes in case you try to shut the processor down BEFORE the changes are written to SD card. Maybe, try just putting a test.txt file into /etc, save it, shut the machine down, re-boot and see if it has disappeared.
Yes,I use a sd card to boot. I have just created a test.txt anh copied it to /etc/ on KIT.Then reboot machine.On PC I use Gftp to KIT.I also see test.txt file :) .But I dont also see /etc/tstab :(
Now i need to edit .rcS file [code] /bin/mount -n -t devpts none /dev/pts -o mode=0622 /bin/mount -n -t tmpfs tmpfs /dev/shm /bin/mount -n -t ramfs none /tmp /bin/mount -n -t ramfs none /var [/code]
