I've got two Mini2440's, one from Hiteg and another from ThaiEasyElec. The one uses a Sony X35 display (portrait 240x320) and the other uses a SP035GT (landscape 320x240). Both Mini's are running the exact same setup but I have to use two different virtual machines when I compile for them such that each gets the correct display setup. I would like to know if its possible to switch in the bootloader and the filesystem to the correct display by looking at a define or something. This way I can eliminate the need for two different VM's. Things affected by the display: - Boot logo (linux\display\drivers\video\logo) - Display driver selection in barebox - Qt Display setup (profile.environment)
Switching between screens
I actually need a way to detect the displays. I don't want go and set a flag either. I just want to compile on one VM and the it should work for both Mini's.
