HI, I am getting below error while downloading zImage in my mini2440 root@aditya-desktop:/home/aditya/Desktop# ./s3c2410_boot_usb zImage Unable to claim usb interface 1 of device: could not claim interface 0: Device or resource busy pls help Thanks in advance.
Error while downloading zImage :Device or resource busy
when tried with x-modem got the below error : Not support XMODEM protocol by this vivi Failed downloading file Number of parameters: 9 name : hex integer ------------------------------------------------------------- mach_type : 000007cf 1999 media_type : 00000003 3 boot_mem_base : 30000000 805306368 baudrate : 0001c200 115200 xmodem : 00000001 1 xmodem_one_nak : 00000000 0 xmodem_initial_timeout : 000f4240 1000000 xmodem_timeout : 000f4240 1000000 boot_delay : 01000000 16777216 Linux command line: noinitrd root=/dev/mtdblock3 init=/linuxrc console=ttySAC0 Supervivi> load flash vivi x Not support XMODEM protocol by this vivi Failed downloading file Any Idea ????
Hi Davef, Thanks for your replay... I don't have windows installed in my system...so I can not use DNW for windows...and DNW for linux I have not tried yet... I found usbpush and flashing using vivi method very simple so I tried these first, but unfortunately got above error in both the method :( have you ever seen this kind of error while flashing ?????
No, I have not because I only ever used DNW on Windows and on Linux I used ./sc32410_boot_usb for loading u-boot only. I never tried loading the zImage with that. I didn't think u-boot could load via USB. I should have asked which bootloader are you using? Maybe, this might help: http://forrestbao.blogspot.co.nz/2008/01/deploying-embedded-linux-to-sam...
I am able to flash the board successfully using DNW software (for windows)
But dont know the reason for the above error( in first two post) in linux
system while flashing.
1: Unable to claim usb interface 1 of device: could not claim interface 0:
2: Supervivi> load flash vivi x
Kernel and bootloader used ---
1: 2.6.32.59 (Kernel)
(aditya@aditya-desktop:~$ uname -a
Linux aditya-desktop 2.6.32.59 #5 SMP Tue May 1 20:55:03 IST 2012 )
2: vivi (bootloader).
Well, at least the version of vivi you are using seems to do the job. Just curious 2.6.32.59 where did this come from? Have you patched it to get it to work on the mini2440? As well as flashing the board does everything else now work?
