No touchscreen Mini2440 linux 3.7.1
halabut
I've compiled linux 3.7.1 using the config file in arch/arm/config/ (minus
IPMI support, for some reason it won't boot when included), and I'm using
the Angstrom rootfs.
X11 and Matchbox work fine, but I can't get the touchscreen to work.  I've
made sure that I've compiled all the kernel options to support touchscreen
(s3c2410 touchscreen and s3c ADC) but I don't get a touchscreen in
/dev/input/ or /sys/class/input, just the GPIO buttons.
I'm sure this has been solved before, has anyone got any insight?
ely
I have the same problem using linux 2.6.39 kernel. The monitor is w35.
Any idea?
Is this a virtual terminal issue?
Device drivers
-> Character devices
   -> [*] Virtual terminal
Then in /etc/inittab add:
console::respawn:/sbin/getty -L 9600 tty1 vt100
On 2nd thought:
Graphics support
-> Console display driver support
   -> <*> Framebuffer Console support
   -> [*] Map the console to the primary display device
   -> [*] Select compiled in fonts
   -> [*] VGA 8*8 font
There are many patches applied to the mainline kernel, possibly even 3.7.1,
to get the mini2440 fully functional.
I would suggest going to this page:
http://www.ptxdist.org/oselas/bsp/pengutronix/mini2440_bsp_en.html
download and extract OSELAS.BSP-Pengutronix-Mini2440-2012.12.0.tgz
and search around for patch files.  Most of them revolve around the
touchscreen and the ADC.
Good luck!
halabut
Thanks, applying the patch worked. Now to set up tslib...
diepa9k39
You try edit /etc/profile then replace into kit by Gftp
=>touchscreen
