Hi all, I am trying to flash Wince image. But there are some bad blocks in my Nand flash and it returns NAND error. Mine is 1GB Nand flash and i am able to install Linux and Android in it. But Wince is not getting installed. So i tried to run the Wince image from SDcard directly. I changed the FriendlyArm.ini file to run Wince NK.bin image. In the serial port it displays the following line and i don't see anything else in LCD or serial port. file: /images/WindowsCE6/NK-i.bin: 45 MB(47504463 Byte) Unpacking NK.bin... Unpacked NK.bin Finished Even i am facing issues installing NBoot.nbo. Using DNW i am able to download but when i try to boot Nboot.nbo from Nand it says "Reading...NK Length Error". All these images i am using is the one provided in the DVD. I am not sure where i am going wrong or its problem with the board as such. But i don't see any issues installing Linux/Android albeit bad block errors comes during the installation. Can someone please help me to install Windows. Thanks, Praveen
Booting Wince in mini6410
I have the same problem. I had no problem to install the NK.BIN but it's not working: after the boot has finished to load NK.bin the system halt. I have a terminal connected to COM1: it says: ".. Launch Windows CE" but then nothing happens. I used the superboot210.bin. It's able to install or run only the NK.bin originally provided by the supplier (We bought a couple of sample from Corewind (www.minidevs.com)) but not the one built from scratch from the BSP Bye
