I have cross compiled Qt4.7.2 and tslib successfully.
I have trafered the compiled tslib and Qt to Mini210s
But when run example program.
It is give following error.
QWSTslibMouseHandlerPrivate: ts_config() failed with error: 'No such file
or di'
Please check your tslib installation!
I found this subject in forum, however everyone doesn't solve this problem
Some one help me come out of this issue.
ts_config() problem
I have tested ts_calibrate, it runs however can't touch screen. Could you help me this problem. Thank you!
Check your /etc/profile, it should contain something like this: export TSLIB_TSEVENTTYPE=INPUT export TSLIB_CONSOLEDEVICE=none export TSLIB_FBDEVICE=/dev/fb0 export TSLIB_TSDEVICE=/dev/input/event1 export TSLIB_CALIBFILE=/etc/pointercal export TSLIB_CONFFILE=etc/ts.conf export TSLIB_PLUGINDIR=/usr/lib/ts if it doesn't, try manually declaring them (just enter into the console) and see if that helps. The device might be event0 ts and the plugindir might be in usr/local/lib, check these.
