Does anybody have a package built which I could use to install X11 Tiny210v2 linux 3.0.8 tablet with the zImage built from source?
Install X11 for linux
you might need to add a bit more to that question Kevin :D do you mean you've created your own 3.0.8 kernel from source? and you want to install X/X11 on the rootfs? What are you using as the rootfs? Debian? qtopia-linux? Ubuntu? If it's debian or ubuntu then you should easily be able to use apt-get to install X/X11, if it's the qtopia-linux image, I'm not entirely sure how it deals with packages and didn't get into the nitty-gritty of cross-compiling for qtopia-linux.
I built using the qtopia-linux 3.0.8 source that I downloaded from the friendarm ftp site for the Tiny210. Qtopia looks like it will accept ipk files but the Package Manager wont let me install the x11 ipk for arm that I found. I was able to copy the libx11.so file out of the ipk and dropped that into the root of my application to make it stop complaining about X11.
I wasn't aware that there was a qtopia-linux 3.0.8 image, you learn something new everyday :D X11 usually isn't that small, there's usually a ton of junk all over the os that it installs, so I'm not entirely sure what you've got going there but if it works, great :) My other thought would be to get something like debian/ubuntu running on it , you can apt-get anything that you need to install once the first stage is done and of course small stuff will compile directly on the 210 itself, you don't have to install a desktop environment of course but there are plenty of lightweight ones around. It also makes it a breeze to develop in qemu. I'd like to see friendlyarm do more with the modern distros as they cut out a lot of development heartache/headaches and leave developers more time to develop.
I did look at Ubuntu but the last set of source had a note that the touchscreen was not supported which made it fairly useless on a tablet. Ubuntu would make my life a lot simpler for this...
well, the touchscreen drivers are really more of a kernel thing but of course it requires setting up and the ts drivers weren't in the 3.0.8 sources afaik) however, there is a thread or 2 on the forums that deals with it, so you might find some information there, perhaps if a few of us got together between us we can thrash it all out into a a decent 3.0.8 kernel with ubuntu/debian that we might be able to submit back to friendlyarm.
If I had the time on this project I probably would try to get Ubuntu working. Its now whining about not being able to find javax.swing.JFrame even though JAVA_HOME is set correctly as is the PATH variable. I wish I knew what java was looking for to find its jars.
Well I tried installing ubuntu following the directions in http://armworks.cc/index.php?title=Mini210S_ubuntu_sd onto my tiny210 but only end up with a white screen so I had to go back to the qtopia based linux. I wasnt even able to get anything out the serial ports so Im not sure what is going on. What are the other two forums with X11 and/or Ubuntu info?
Hi Kevin, the other forums that you're asking about, it's actually a couple of posts on THIS forum :-) I actually wrote the tutorial that you worked from, did you get any console output from com1 when you booted the SD card? You'll also notice that it was written for a mini210S, not a tiny210, so you may need to build yourself a kernel from the tiny210 kernel source code, lastly, which LCD panel do you have? You might need to fixup the cmdline in FriendlyArm.ini to point to the correct LCD.
I didn notice the change but figured that it would be minimal so I used the zImage I built from the ubuntu source I downloaded from friendlyarm for the tiny210 and changed the display type in FriendlyArm.ini to the S70 which is what I am using. No I didnt see any output on either COM1 or COM2 when booting. I had putty setup for 115200 since thats what I saw in FriendlyArm.ini.
Well it looks like we are scrapping using linux so Im focusing on Android (yeah I do get the irony that android is sitting on linux).
Kevin, I revisited my SD booting tutorial last night,I may have forgotten to put a step in, you need to disable the initrd/initramfs stuff in the kernel config and put noinitrd in the cmdline in FriendlyArm.ini
