"Device or resource busy" when mounting USB
eduardo
Attachment: usberror.txt (1.12 KB)
Hi all,
I'm trying to mount a simple pen drive on micro 2440, but the following
error always return:
mount: mounting /dev/sda on /home/plg/pen/ failed: Device or resource busy
When I use my mp4 I don't get this error, but any other data storage
equipment doesn't work.
I can't find out any reason for this error or any explanation about this.
Anyone know any site/book or tip that will help-me?
thanks in advance
eduardo
Attachment: usb.txt (1.31 KB)
This attachment contain the log when I mount the mp4 device. And it works
fine.
I will look for differences to mount "Flash Disk" and "USB MASS STORAGE
CLASS"... but i don't know if this will help me.
scsi scan: INQUIRY result too short (5), using 36
Noticed in cruising around kernel options that something like
SCSI_SCAN_WAIT is a loadable module.
Sorry, haven't got my FriendlyArm setup at work to verify the actual
option.
HTH
Dave
eduardo
Hi davef,
Thank you for your reply.
I discovered that the devices were being automatically mounted on /udisk.
(what a noob i am... u.u)
Anyway, thanks again for your reply.
regards
lalitha
when i try to mount pendrive  i get following error and able to see content
of pendrive
mini2440#mount /dev/sda1 /media
FAT: codepage cp437 not foõnd
mount: wrïng fs tùpe, bad optioî, bad sõperblock on /äev/sda1,
       missing codepage oò helper program, or other error
       In some cases useful info is found in syslïg - try
       dmesg | tail  or so
mini2440#mount /dev/sda1 /mnt
       dmesg | tail  or so
sudhanshu
go to root
cd /
see if you find udisk folder.
this folder contain everything that you have in pendrive. copy it and use
it
sudhanshu
oops u know answer already :-)
