Any here running any of the Mini210 or Tiny210 boards with Android? I have a Mini210 with Gingerbread and the WiFi does not stay active even when I apply a WiFi lock. After the power down, the wpa_supplicant keeps trying to initiate a wifi scan but fails. I have the settings set for 30 mins in Android but the WiFi powers down after about 6 mins if there is no net access from any application. The logcat shows the following when it fails. (deleted stuff to clean it up) wpa_supplicant(137): CTRL-EVENT-DISCONNECTED - Disconnect event - remove keys wpa_supplicant(137): CTRL-EVENT-STATE-CHANGE id=0 state=0 WifiMonitor(95): Event [CTRL-EVENT-DISCONNECTED - Disconnect event - remove keys] WifiMonitor(95): Event [CTRL-EVENT-STATE-CHANGE id=0 state=0] WifiStateTracker(95): New network state is DISCONNECTED WifiStateTracker(95): Changing supplicant state: COMPLETED ==> DISCONNECTED Alarm System(1093): SUPPLICANT_STATE_CHANGED_ACTION wpa_supplicant(137): CTRL-EVENT-STATE-CHANGE id=0 state=2 WifiMonitor(95): Event [CTRL-EVENT-STATE-CHANGE id=0 state=2] WifiStateTracker(95): Changing supplicant state: DISCONNECTED ==> SCANNING Alarm System(1093): SUPPLICANT_STATE_CHANGED_ACTION wpa_supplicant(137): ioctl SIOCGIWSTATS failed, errno = 95 wpa_supplicant(137): ioctl SIOCGIWRATE failed, errno = 95 wpa_supplicant(137): FAWEXT: noise = 0 (0), level = -50 (206) wpa_supplicant(137): FAWEXT: noise = 0 (0), level = -36 (220) wpa_supplicant(137): FAWEXT: noise = 0 (0), level = -80 (176) wpa_supplicant(137): FAWEXT: noise = 0 (0), level = -77 (179) wpa_supplicant(137): CTRL-EVENT-SCAN-RESULTS Ready wpa_supplicant(137): Trying to associate with 00:14:6c:3e:b4:de (SSID='dave_lockedout' freq=2437 MHz) wpa_supplicant(137): CTRL-EVENT-STATE-CHANGE id=0 state=3 WifiMonitor(95): Event [Trying to associate with 00:14:6c:3e:b4:de (SSID='dave_lockedout' freq=2437 MHz)] WifiMonitor(95): Event [CTRL-EVENT-STATE-CHANGE id=0 state=3] WifiStateTracker(95): Changing supplicant state: SCANNING ==> ASSOCIATING wpa_supplicant(137): CTRL-EVENT-STATE-CHANGE id=0 state=4 wpa_supplicant(137): Associated with 00:14:6c:3e:b4:de wpa_supplicant(137): CTRL-EVENT-STATE-CHANGE id=0 state=7 wpa_supplicant(137): CTRL-EVENT-CONNECTED - Connection to 00:14:6c:3e:b4:de completed (reauth) [id=0 id_str=] Any help appreciated. I have been tearing my hear out for weeks on this now and still can't find a solution.
