Hi, I need your help to understand something about cross compiling: When building a new system, everything should be consistent. The same compiler should be used for building the filesystem apps, compiling new applications and so on. This ensures to have the correct libraries versions in the file system to guarantee compatibility with applications. This is the case using tools like pengutronix PTXdist, or buildroot and so on My question is more about using "general distro" like Debian. In that case, you don't know which compiler was used to build the packages. How to be sure to cross compile applications that won't have any conflicts with your system? To be more precise, I have a debian 5.0.8 on my system, I don't know the glibc version, and other libraries. There is no gcc compiler on it. I would like to cross compile Transmission for this system, but I don't know how to do it. Should I just take the last CodeSourcery Gcc compiler and compile transmission with armv5te option? Doing like this may create incompatibilities as Debian 5 is quite old, and Gcc will be a new version. Can somebody light my candle? Thank you!
Cross compiling an app
As you seem to be familiar with PTXdist why not just use their toolchain? I did that for msmtp before being encouraged to write my own rule files and use their build system as well.
Hi Dave, Thanks for your reply. There are two reasons for which I don't use PTXDist: - first, I'm curious and I would like to learn. I have this question since a long time now - but the best reason is I can't. In fact, the target for this question is not a mini, but a Iomega Ix2-200 NAS. It has a firmware based on Linux Debian 5.0.8, and it is installed onto image files. So each time the NAS boots up, it uncompresses the image to get the root filesystem. As the torrent client is very poor in term of functionnalities, I would like to install transmission instead. I managed to make it work on my mini210s, but now I need to have it working on the NAS itself. Juergen explained me in another post it was important to have a consistant filesystem with the toolchain, that's why I wonder how it works with official distros as it's not as easy as PTXDist configurations.
I think most of the time you get away with it. However, in my experience I didn't seem to get away with it often enough! And if your debugging skills are poorly-developed then you waste days and weeks trying to get things to work. How do the OpenEmebbed and BuildRoot guys handle these issues? I have never used either system. Some groups use OpenEmbedded at work, but I am not working with them so never hear how easy or difficult it is to use.
I would look at the underlying processor of the whole thing and take it from there, look for the source code (it should be gpl'd if it's running debian) from iomega or openwrt would be a good place to look too.
Debian based binary archives are built in nearly the same manner like PTXdist does it: they use a specific toolchain, a tested patch set, a valuable configuration for the package and at the end, the results are packaged into a *.deb archive. You should get in touch with the ARM Debian maintainers. Maybe they can offer you a reliable way to create your own application's archives. matching all the existing dependencies of your currently running root filesystem. Keep in mind: also the Debian mainainers need a reliable way to create their *.deb archive pool. We have a Debian maintainer here at Pengutronix. I will ask her how to proceed. Please be patient.
Screwface, check here for general info about your nas, http://iomega.nas-central.org/wiki/Category:Ix2-200 More specifically here for how to put debian on it :-) http://blog.nobiscuit.com/2011/08/06/installing-debian-to-disk-on-an-ix2...
Hi, Thank you very much Reggie for your links. I already knew those websites. I don't want to install a fresh debian on the NAS because I will loose all the functionnalities provided by supplier, I mean Web interface, all servers and so on. I would need to reconfigure everything. But it could be a good solution to do this, to get a full custom NAS installation. But it's time to spend... Juergen, thank you very much for your valuable help (as usual!). I didn't know the process to create the packages, I thought there was an "official" toolchain but was not sure. I'll wait for your advices. Thanks again to help me on this issue
Screwface, it seems not that trivial how to generate matching deb packages for an existing distribution. All I know right now is, they build their distribution packages natively(!). It seems they do not use cross compilers. But my information is still not complete. Give me some more time.
can't you grab a binary from the existing unit and query it to see how it was built? Of course I realise that it's not necessarily going to give you the information you need but readelf and ldd can be quite useful, especially if they left debugging turned on. If it's based on debian then they probably didn't build it from the ground up and it's probably based on armel. Also, if it's got uboot on it, there is nothing to stop you test running different kernels/rootfs, does it have an sd card on it, that should be simple enough to boot from? Or with it being a NAS I expect it to have networking, in theory you should be able to test tftp booting and nfs rootfs, totally non destructive, you can set all your necessary commands to boot the kernel via tftp and set bootargs to run from nfs rootfs, then once you do a power cycle, any changes you made are gone, they're only committed to flash when you do a 'saveenv' in uboot. Lastly, did you actually go looking for the ix2-200 source code? https://iomega-na-en.custhelp.com/app/answers/detail/a_id/22898 Downloading that will instantly tell you which glibc version it's using. http://forum.nas-central.org/viewtopic.php?f=243&t=4205 Also hints at being able to update a non-cloud version of the ix2-200 to a cloud version. If you look through the source code, you will see the glib version, what's not necessarily so apparent is the gcc version that they're using, it's 4.3 apparently. I'll leave you to download the source and figure out the glibc version :-)
I already downloaded the source code, and already thought about modifying kernel or creating a new system, but it's a huge workload for a non professional person. Iomega delivers the kernel, the vanilla one if I'm right, and they give some patches to apply. But the kernel is common to several NAS (ix4-200), and I'm a bit lost and confused. Furthermore, I'm not familiar with patch command and process. But I already used tftp boot when I tinker a bit too much, the nas didn't boot. So there is no SD-Card slot, but yes, uboot allows to connect to tftp and nfs servers. I executed libc yesterday. It's version is 2.8, compiled with Gnu CC 4.3.2 But it's not so easy to tweak the system as it uses a non common architecture compared to mini or other bevboards: the filesystem is not written to a partition and accessed by the kernel directly. There are 5 main image files written to a partition. Mainly, one contains the binaries (Apps image file), another the kernel, a third one contains initrd. I understood roughly how it works, but there are some details I have not discovered yet. Apps filesystem is mounted in RAM, so each time you make modifications or try to install an application, it is lost at next reboot. It is very instructive and I learn a lot digging into minis or this NAS. The problem is I used the NAS also as my tftp/nfs server for mini210 / mini2440, and it is unusable for the moment :-) I found this way to install transmission, but I thought it was not a good idea to use non debian packages because of library consistency. I feared the glibc and cross compile tool chain used to compile those packages may differ from my system's one and may cause failures. To be honnest, everything is not clear in my mind. I understand the correct way is to generate all the binaries, libraries and so on with the same toolchain. PTXdist case is ok. But using NSLU2 packages on other systems is not clear for me, is the fact that is works pure luck, or is there another reason I don't understand? And if I go farther in this way, when you have a linux distribution on your PC, let's say i386. You have Gcc already installed and you are able to generate binaries consistent with your system. But you can also install third party compiler like CodeSourcery one. In this last case, libraries (glibc or other) may differ from the host system, so I'm a bit confused. So for the moment, the only way I found, as Juergen explained it is quite hard to generate debian binaries, is to extract NSLU2 repository *.ipk packages files, mount the Apps image, integrate *.ipk content in the image, and install the whole customized system this way: http://iomega.nas-central.org/wiki/Category:Ix2-200-usb-init It's not the perfect way, but it's a try. I'll let you know! I'll also have to write the /etc/rcX.d/SXX_transmission file, another topic to understand and learn! PS: correct source code is this one https://iomega-na-en.custhelp.com/app/answers/detail/a_id/26776 One last thing: I'm sorry to debate this non FriendlyARM subject here, but I didn't know where to get embedded systems development answers to my questions. And as there are here very qualified persons like you both... Again, thanks a lot for your help
I forgot to give the link of NSLU2 transmission package installation on ix2-200: http://techmonks.net/installing-transmission-and-dnsmasq-on-a-nas/
It seems to me that as long as you've got access to uboot then you can mess around however you like (as long as you don't wipe uboot). As for 'building' it yourself, with debian etc. you essentially don't really build much yourself, just the kernel, everything is pre-built, you just have to bootstrap the image. For instance, I recently 'built' my own ubuntu for the mini210S, it starts with me compiling a kernel, that's about all you have to do for the compiling stage, the rest of the install is done for you. you use a 'first stage' installer, this gets enough of a simple rootfs onto a system to allow you to complete the 2nd stage which will involve a fair bit of downloading from ubuntu repos but again, everything is done for you. You just have to 'apt-get' any extra stuff you might want. Also, don't worry about it not being an FA subject, I think I had a moan at someone a while back for discussing a competitors board but I'm over that stuff now :D Lastly, if you can recover the NAS to its original state then I probably wouldn't worry so much about breaking stuff if I were you. Very Lastly, I would at the very least join that forum http://forum.nas-central.org and ask some questions. Very, very lastly this time, looking at the techmonks post, it's all very well explained there for you, it might be using nslu2 repos but the tutorial is written for a stock ix-2 so I would take a strong guess that they're binary compatible :-)
Reggie, In fact, when I said it's a huge workload to create a non system, I didn't mean I wanted to create all by myself. Of course, installing a newer Debian distribution would be easy (and I think I saw a webpage explaining that). I was more talking about configuring everything, and designing a new web interface to manage everything. I don't want to have to connect to a ssh session each time I want to start or stop a mediaserver for example. But yes, I already dreamed about an armel version of FreeNAS, or some open source NAS software which can be installed on many different systems (Synology, Netgear, Qnap...). So installing a complete system would be quite easy, the same way it can be done on a desktop PC, but having a fully functionnal system is much more work. Maybe one day, when I'll have more time, I'll do it. But you're right, I could use uboot tftp/nfs abilities to create a new system without risk for the embedded system. Regarding nas-central forum, unfortunately it is more a 'NAS usage' forum than a 'developper / improvement' one. That's why I preffered to post here, and I think my questions are not really system specific. Everybody can ask the same principle questions about using debian and creating apps for the minis. By the way, as I explained in my previous post, I'll adapt techmonks method, and create new installation files in which many people will be interested in (according to Iomega forum). But I still have my questions! :D Maybe Juergen will be helpful to me to understand! Thanks
wrt. the nas-central site, yes, it's a nas usage site but there are actually people on there that discuss development for NAS units, so at the very least it's a starting point with people that might actually know your project :) I'm not saying stop asking about it here, just saying that you're more likely to find someone that can help directly rather than giving the random advice that I'm giving. as for techmonks, I don't think you need to adapt it at all, it's written for ix2 units :-)
