mini6410 Android 2.3 compilation
Praveensesha
When i compile mini 6410 Android 2.3 in Ubuntu 12.04 64 bit system i am
getting the following error,
Could not load 'clearsilver-jni'
java.library.path = out/host/linux-x86/lib
make: *** [out/target/common/docs/doc-comment-check-timestamp] Error 45
make: *** Waiting for unfinished jobs....
make: *** [out/target/common/docs/api-stubs-timestamp] Error 45
 'out/target/common/obj/APPS/Launcher2_intermediates//classes.dex' as
'classes.dex'...
Surfed google to find its a problem with JDK and i tried installing sun
java 1.6 but its still not getting compiled. Has anyone solved this
problem? Please help.
Dave McLaughlin
I found this issue was caused by the JDK 1.6 that is supplied with the
source. It is a 32 bit version as far as I can tell.
Edit the build file and comment out the extraction of the JDK and also
delete the one that was created the first time you ran this.
Praveensesha
Thanks Dave. I compiled. I installed 64 bit sun JDK but build was using JDK
provided in the source. Mapped correct JDK and compilation was done.
Dave McLaughlin
Awesome. Well done and thanks for replying to let us know.
