Hi, I saw CE logo printed on some boards: micro2440 and mini2440. I would like to know if these products comply to european rules about electronic equipments. Can you tell me something about lcds and their boards? are they compliant?
CE certification
Quite right. You do need to take precautions when using the micro2440 in any design. We struggled to get this board to pass the EMC emissions test. When executing any program this board radiated at 50.625MHz (peripheral clock), 101.25MHz (memory clock), 151.875MHz (3rd harmonic), 202.5MHz (4th harmonic) and so on. I'd suggest ferrite beads on all lines and a screen the lot with a can!
Hello, We are also trying to get this board to pass CE certification. Can you send me detailed procedure what we need to do (where to put beads and the can)? I would be very appreciated. Thanks a lot!
We are also heaving difficulties passing radiation test. The Friendlyarm board is mounted into 1mm metal enclosure (with openings) and well grounded through all four mounting holes. Attached is printout of Radiation scan. We tried with different grounding, adding ferrite near CPU but couldn't get rid of 500Mhz peak. Where should we put ferrite beads? Around supply lines, and all I/O? what kind of ferrite do you prefer? Any idea will be very appreciated. Tnx! Simon
Hello, I need mini2440 with CE certificate for my projects in Europe, does anyone have a solution? Maybe we could get together and share the costs more?
