Mini210 WinCE6 ROM Only FS
dezso
How to change from RAM/ROM to ROM only, changing in the BSP ROM only just
generate a unusable bin image.
There is more to that than clicking a check-mark ?!
NothinRandom
How do you get it to compile without errors? Every time, I always get one
error. However, it doesn't tell what the error is...so I can't generate.
kuhdav
I 'm also interested in this issue butI I even failed to run the NK.BIN
built from their BSP (which uses RAM/ROM).
After boot it doesn't start!!! (BUT THEIRS DO)
Does your NK.BIN start?
Satish
Anyway the NK.BIN I found on the DVD (included with board) get loaded and
work properly.
i build an image with out errors but after boot it doesn't start!!!
Thamer
Have anybody managed to get the rom only fs running on mini210s or
tiny210v2?
Really I need help here
kuhdav
There's another therad on the same subject.
Look at there for my answer and see if it can help you.
http://www.friendlyarm.net/forum/topic/4454
bye
Thamer
Dear khudav
Actually I have tried your solution but it is not working, the generated
image fail to boot to desktop after installation .
Chris
It would be great if anyone can help us out with this. I can't get it to
work on my Mini210s either.
Dezso
I understand this is a community based support forum but posted this close
to 10 month and as I can see not the only one looking for answer.
Would expect some work being done on this subject by friendlyarm who is
doing fine on the sale but not very well on support.
Dezso:
