Hi all, I am new to Linux and want to install the USB Bluetooth module on Linux kernel, what are the process to follow, I have created zImage by selecting (enabling) in Bluetooth subsystem, also enabled the usb drivers, and installed the generated zImage on Tiny6410 with supervivi and rootfs (QTopia File system). After rebooting the system and inserting the module on board it will show that module is detected but does not accept HCI commands. what will be the problem, how to enable the HCI command. what are the process to follow to attach another Bluetooth device with tiny6410. I am clueless now and kind find the path, please suggest anything if you have any idea.
CSR USB Bluetooth on linux
I got some solution, I am able to run the commands and scan the nearby bluetooth devices but not able to connect with bluetooth devices. If any idea how to configure pin please suggest me... I followed following sequence I build the kernel with bluez stack enable all the bluetooth parameter are selected as a kernel module with [*] and with usb hci support. then we need to download the bluez-libs-2.25.tar.gz and bluez-utils-2.25.tar.gz and bluez-hcidump-2.30.tar.gz from www.bluetooth.org Cross compile it with bluez-libs-2.25 with arm-linux-gcc. Cross compile it with bluez-utilis-2.25 with arm-linux-gcc. Cross compile it with bluez-hcidump-2.30 with arm-linux-gcc. with cross compile generate the root file system with name as bluez-rootfs.... and copy the generated etc and usr folder to rootfs_qtopia_qt4 then we are able to run the hcitool command.
sorry for download link given its not www.bluetooth.org the correct link is http://www.bluez.org/download/ download following packages from the link bluez.sf.net/download/bluez-libs-2.25.tar.gz bluez.sf.net/download/bluez-utils-2.25.tar.gz
I am still not able to connect the bluetooth devices I have followed below sequence to cross compilation of bluez stack. I am able to scan the nearby devices. but not able to connect then. by sensing hcitool auth <bdaddr>, the tiny 6410 will respond with following error mesage HCI authentication request failed: Connection timed out please suggest if any one have any idea. 2016 cd 2017 mkdir tiny6410 2018 cd tiny6410/ 2019 tar xvzf /media/Bb/FriendlyARM/DVD\ 1/Linux/arm-linux-gcc-4.5.1-v6-vfp-20101103.tgz 2020 tar xvzf /media/Bb/FriendlyARM/DVD\ 1/BlueZ\ tools/bluez-libs-2.25.tar.gz 2021 tar xvzf /media/Bb/FriendlyARM/DVD\ 1/BlueZ\ tools/bluez-utils-2.25.tar.gz 2022 tar xvzf /media/Bb/FriendlyARM/DVD\ 1/BlueZ\ tools/bluez-hcidump-2.3.tar.gz 2023 mkdir bluez-rootfs 2024 ls 2025 ls -l 2026 cd bluez-libs-2.25/ 2027 export PATH=$PATH:/home/administrator/tiny6410/opt/FriendlyARM/toolschain/4.5.1/bin/arm -linux- 2028 export CC=/home/administrator/tiny6410/opt/FriendlyARM/toolschain/4.5.1/bin/arm-linux-g cc 2029 export GCC=/home/administrator/tiny6410/opt/FriendlyARM/toolschain/4.5.1/bin/arm-linux-g cc 2030 export RANLIB=/home/administrator/tiny6410/opt/FriendlyARM/toolschain/4.5.1/bin/arm-lin ux-ranlib 2031 export LD=/home/administrator/tiny6410/opt/FriendlyARM/toolschain/4.5.1/bin/arm-linux-l d 2032 export NM=/home/administrator/tiny6410/opt/FriendlyARM/toolschain/4.5.1/bin/arm-linux-n m 2033 export AS=/home/administrator/tiny6410/opt/FriendlyARM/toolschain/4.5.1/bin/arm-linux-a s 2034 export AR=/home/administrator/tiny6410/opt/FriendlyARM/toolschain/4.5.1/bin/arm-linux-a r 2035 ./configure --build=i686-pc-linux-gnu --host=arm-linux --sysconfdir=/home/administrator/tiny6410/bluez-rootfs/etc --prefix=/home/administrator/tiny6410/opt/FriendlyARM/toolschain/4.5.1/arm-none- linux-gnueabi 2036 make following error found in after hitting make sdp.c:426:17: error: 'USHRT_MAX' undeclared (first use in this function) add #include <limits.h> file in sdp.c file located at bluez-libs-2.25/src/sdp.c file marked with + sign #include <stdio.h> #include <errno.h> #include <unistd.h> #include <stdlib.h> #include <malloc.h> #include <syslog.h> #include <sys/un.h> +#include <limits.h> #include <sys/socket.h> #include <sys/time.h> #include <sys/types.h> 2037 ./configure --build=i686-pc-linux-gnu --host=arm-linux --sysconfdir=/home/administrator/tiny6410/bluez-rootfs/etc --prefix=/home/administrator/tiny6410/opt/FriendlyARM/toolschain/4.5.1/arm-none- linux-gnueabi 2038 make 2039 make install 2040 sudo make install 2041 cd .. 2042 cd bluez-utils-2.25/ 2043 history 2044 ./configure --build=i686-pc-linux-gnu --host=arm-linux --mandir=/home/administrator/tiny6410/bluez-rootfs/usr/share/man --sysconfdir=/home/administrator/tiny6410/bluez-rootfs/etc --localstatedir=/home/administrator/tiny6410/bluez-rootfs/var --prefix=/home/administrator/tiny6410/bluez-rootfs/usr 2045 make add #include <limits.h> file in /home/administrator/tiny6410/bluez-utils-2.25/tools/hciattach.c #include <stdio.h> #include <errno.h> #include <fcntl.h> #include <unistd.h> #include <stdlib.h> #include <string.h> #include <signal.h> #include <syslog.h> +#include <limits.h> #include <termios.h> #include <time.h> #include <sys/time.h> #include <sys/ioctl.h> #include <sys/socket.h> 2046 ./configure --build=i686-pc-linux-gnu --host=arm-linux --mandir=/home/administrator/tiny6410/bluez-rootfs/usr/share/man --sysconfdir=/home/administrator/tiny6410/bluez-rootfs/etc --localstatedir=/home/administrator/tiny6410/bluez-rootfs/var --prefix=/home/administrator/tiny6410/bluez-rootfs/usr 2047 make error Found hciconfig.c:732:16: error: 'PATH_MAX' undeclared (first use in this function) add #include <limits.h> file in /home/administrator/tiny6410/bluez-utils-2.25/tools/hciattach.c #include <stdio.h> #include <errno.h> #include <ctype.h> #include <unistd.h> #include <stdlib.h> #include <string.h> +#include <limits.h> #include <getopt.h> #include <sys/ioctl.h> #include <sys/socket.h> 2048 ./configure --build=i686-pc-linux-gnu --host=arm-linux --mandir=/home/administrator/tiny6410/bluez-rootfs/usr/share/man --sysconfdir=/home/administrator/tiny6410/bluez-rootfs/etc --localstatedir=/home/administrator/tiny6410/bluez-rootfs/var --prefix=/home/administrator/tiny6410/bluez-rootfs/usr 2049 make error found request.c:654:23: error: 'USHRT_MAX' undeclared (first use in this function) add following to /home/administrator/tiny6410/bluez-utils-2.25/sdpd/request.c #include <stdio.h> #include <errno.h> #include <malloc.h> #include <syslog.h> #include <sys/socket.h> +#include <limits.h> #include <bluetooth/bluetooth.h> #include <bluetooth/sdp.h> #include <bluetooth/sdp_lib.h> 2050 ./configure --build=i686-pc-linux-gnu --host=arm-linux --mandir=/home/administrator/tiny6410/bluez-rootfs/usr/share/man --sysconfdir=/home/administrator/tiny6410/bluez-rootfs/etc --localstatedir=/home/administrator/tiny6410/bluez-rootfs/var --prefix=/home/administrator/tiny6410/bluez-rootfs/usr 2051 make error found sdp.c:74:16: error: 'PATH_MAX' undeclared (first use in this function) add #include <limits.h> to /home/administrator/tiny6410/bluez-utils-2.25/hidd/sdp.c #include <stdio.h> #include <errno.h> #include <fcntl.h> #include <unistd.h> #include <stdlib.h> #include <malloc.h> +#include <limits.h> #include <string.h> #include <sys/stat.h> #include <sys/socket.h> 2052 ./configure --build=i686-pc-linux-gnu --host=arm-linux --mandir=/home/administrator/tiny6410/bluez-rootfs/usr/share/man --sysconfdir=/home/administrator/tiny6410/bluez-rootfs/etc --localstatedir=/home/administrator/tiny6410/bluez-rootfs/var --prefix=/home/administrator/tiny6410/bluez-rootfs/usr 2053 make 2054 make install Installation of bluez-utilis-2.25 completed successfully 2055 cd .. 2056 cd bluez-hcidump-2.3/ 2057 ./configure --build=i686-pc-linux-gnu --host=arm-linux --mandir=/home/administrator/tiny6410/bluez-rootfs/usr/share/man --prefix=/home/administrator/tiny6410/bluez-rootfs/usr 2058 make 2059 make install Installation of bluez-hcidump-2.3/ completed successfully Now extract the rootfs_qtopia_qt4-20120517.tar.gz in tiny6410 folder 2060 cd .. 2061 tar xvzf /media/Bb/FriendlyARM/DVD\ 1/Linux/rootfs_qtopia_qt4-20120517.tar.gz permission required 2062 sudo tar xvzf /media/Bb/FriendlyARM/DVD\ 1/Linux/rootfs_qtopia_qt4-20120517.tar.gz 2063 cp -r /home/administrator/tiny6410/bluez-rootfs/ /home/administrator/tiny6410/rootfs_qtopia_qt4/ copy the content of /home/administrator/tiny6410/bluez-rootfs/ to /home/administrator/tiny6410/rootfs_qtopia_qt4/ 2065 sudo cp -r /home/administrator/tiny6410/bluez-rootfs/etc/ /home/administrator/tiny6410/rootfs_qtopia_qt4/ 2066 sudo cp -r /home/administrator/tiny6410/bluez-rootfs/usr/ /home/administrator/tiny6410/rootfs_qtopia_qt4/ 2067 sudo cp -r /home/administrator/tiny6410/bluez-rootfs/var/ /home/administrator/tiny6410/rootfs_qtopia_qt4/ 2068 cd rootfs_qtopia_qt4/ 2070 ls 2071 cd .. 2073 mkubimage-mlc2 rootfs_qtopia_qt4/ rootfs_bluez_2.25.ubi 2074 sudo mkubimage-mlc2 rootfs_qtopia_qt4/ rootfs_bluez_2.25.ubi 2075 sudo minicom and install the superboot, kernel zImage and rootfs_bluez_2.25.ubi into the tiny6410 board. after installation completed the command shows that linraries are not found we need to reinstall the libraries by using following command 2078 cd bluez-libs-2.25/ 2079 ./configure --build=i686-pc-linux-gnu --host=arm-linux --includedir=/home/administrator/tiny6410/bluez-rootfs/usr/include/ --libdir=/home/administrator/tiny6410/bluez-rootfs/usr/lib --sysconfdir=/home/administrator/tiny6410/bluez-rootfs/etc --prefix=/home/administrator/tiny6410/opt/FriendlyARM/toolschain/4.5.1/arm-none- linux-gnueabi 2080 make 2081 make install 2082 sudo make install 2083 cd .. 2084 sudo rm -rf rootfs_bluez_2.25.ubi 2085 sudo cp -r /home/administrator/tiny6410/bluez-rootfs/etc/ /home/administrator/tiny6410/rootfs_qtopia_qt4/ 2086 sudo cp -r /home/administrator/tiny6410/bluez-rootfs/usr/ /home/administrator/tiny6410/rootfs_qtopia_qt4/ 2087 sudo cp -r /home/administrator/tiny6410/bluez-rootfs/var/ /home/administrator/tiny6410/rootfs_qtopia_qt4/ 2088 sudo mkubimage-mlc2 rootfs_qtopia_qt4/ rootfs_bluez_2.25.ubi and install the superboot, kernel zImage and rootfs_bluez_2.25.ubi into the tiny6410 board. Board is running and scanning the nearby bluetooth devices.
We are integrating CSR8510 dongle with Android kitkat on TI Beaglebone black. Do you have any guide to integrate the USB dongle to Android system
