Hello, I'm trying to compile latest u-boot for mini2440. For this porpuse I downloaded the latest version from Denx webpage. Then, I do the next steps: make ARCH=arm mini2440_config make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabi- After of that, it is generated 136 KB "u-boot.bin" image. Then, when I burn it into the board, It doesn't work at all. What could be happen ? Thanks !
Compile latest u-boot
Is there a reason for not using u-boot as supplied on the downloads page? What size of mini2440 do you have?
Hello Davef, I need to change the default serial port output of u-boot in mini2440 from "port 0" to port "1", because I need plug a custom device on the first serial port. Thank you.
Can't help with that. You should state which size flash your mini2440 has as how u-boot is configured changes with the flash size. Good luck
I'm interested to know the answer. So I have the board with 256M nand flash. I know that the latest u-boot hangs, and I haven't got to debugging yet. How specifically should the latest u-boot be configured to be able to run on the mini2440?
